向 Identity Object 申请Reset服务时,有两个参数可供选择:
0 Emulate as closely as possible cycling power on the item the Identity Object represents.
1 Return as closely as possible to the out–of–box configuration, then emulate cycling power as closely as possible.
请问这两种Reset有何区别?out–of–box 是什么意思?谢谢!
