国外LonWorks/IP新产品介绍(一) 点击:1563 | 回复:0
gongkongedit
  • 精华:1099帖
  • 帖子:14392帖 | 54470回
  • 历史总积分:622
  • 注册:2008年9月08日
发表于:2002-08-20 09:00:00
国外LonWorks/IP新产品介绍(一) Plexus Technology have a range of web based servers with the following features: NetServer Products · Java Based Web Serving · Web Based Configuration · Extensive o Data Logging o Scheduling o Alarm Handling · Hosting of LNS Database (NSX-100/NSX-1000 only) · Completely Scalable · Data Transfer using open IT standards (ODBC, XML, ACTIVE-X) · Engineering Tools significantly reduces Engineering Time to implement - INCLUDED WITH THE PRODUCT · Connectivity to more than 100 Proprietary or other Open Protocols (NSX-1000 only) The range starts with the NSX-10 device which is extremely low cost and can be connected directly to the NSX-1000 via IP using the built in drivers to provide a totally scalable solution. If this is of interest to you, please get in touch with me. Best Regards Sean Sean Williams sean@plexus-technology.com Plexus Technology Limited 40 High Street Stone Staffordshire ST15 8AU Tel : +44 (0) 1785 615 915 Fax: +44 (0) 1785 615 916 Mobile: 07958 947859 www.plexus-technology.com 注:基本功能同i.LON 100
