下载Lonworks开发工具最新补丁SP--支持CYPRESS3120/3150/FT3120/3150 点击:1762 | 回复:0
yz
  • 精华:14帖
  • 帖子:38帖 | 137回
  • 历史总积分:320
  • 注册:2001年6月28日
发表于:2001-09-03 09:50:00
LonBuilder 3.01 Service Pack 4 and NodeBuilder 1.5 Service Pack 7 Now Available! Download these service packs to get the latest development tools and Neuron Chip Firmware, including support for the new Cypress 3120 and 3150 Chips, and the new Echelon FT 3150 and FT 3120 Smart Transceivers. LONBUILDER安装指南: =============================================== LonBuilder® Developers Kit Readme File Version 3.01.04, July 2001 =============================================== Copyright © 1990-2001 Echelon® Corporation. All Rights Reserved. This file contains important information not included in the LonBuilder documentation. Additional information and updates, including critical updates, may be available in Echelons Developers Toolbox at www.echelon.com/toolbox. This file was installed when you applied LonBuilder 3.01 Service Pack 4. Service Pack 4 automatically detects the current service pack level of LonBuilder 3.01 software and brings the LonBuilder software up to the current LonBuilder 3.01 Service Pack 4 revision. The service pack level can be seen in the LonBuilder software by selecting the About command in the LonBuilder menu. The Version should show as 3.01, and the Build number is 4 reflecting that Service Pack 4 has been applied. This file includes the original LonBuilder 3.01 ReadMe file, as well as updates from Service Packs 1, 2, 3 and 4. CONTENTS ======== 1. Release Identification 2. Installation Instructions 3. FT 3120/3150 Smart Transceiver Application Migration Checklist 4. Service Pack History 4.1 Service Pack 4 4.1.1 Fix for 3150 Network application loading failure 4.2 Service Pack 3 4.2.1 20 and 40MHz Operation 4.2.2 Neuron Clock Upgrade Utility 4.2.3 NEI to NFI File Conversion Utility 4.2.4 Extra On-Chip Memory 4.2.5 Neuron Chip Firmware Version 12 4.2.5.1 On-Chip Library Functions for 3120s 4.2.5.2 LNS Loader Optimizations 4.2.5.3 Refresh Memory Function Deleted 4.2.5.4 Increased Memory Usage 4.2.6 Neuron Chip Firmware Version 9 Corrections 4.2.7 Neuron C Linker 4.2.8 Neuron Type File 4.2.9 EEBLANK 4.3 Service Pack 2 4.4 Service Pack 1 5. Errata for the LonBuilder Users Guide - Revision 3 6. Errata for the Neuron C Reference Guide - Revision 1 7. Errata for the Neuron C Reference Guide - Revision 2 8. Errata for the Neuron C Programmers Guide - Revision 3 9. Errata for the Neuron C Programmers Guide - Revision 4 10. Errata for the LonBuilder Hardware Guide - Revision 4 1. RELEASE IDENTIFICATION ========================== This ReadMe file applies to the following products: LonBuilder 3.01 dated 4/11/1996 Service Pack 4 changes the version number reported by the LonBuilder software to "3.01 Build 4." Service Packs 3 and 4 add support for the following Neuron® Chip Firmware images: 3120E4 (Version 12) 3150 (Version 12) Following is a summary of the previous service packs: Service Pack 1 dated 12/17/96 Service Pack 2 dated 7/6/99 (updated 7/15/99) Service Pack 3 dated 7/9/01 Service pack 4 can be applied to any existing LonBuilder 3.01 installation. It may also be applied to installations with any of the previous service packs. It adds or modifies the necessary files to bring the LonBuilder software to the current release version. Service Pack 4 is cumulative. It incorporates all previous service packs (1 - 3), as well as interim releases of firmware files for Neuron 3120® E1, E2, E3, E4, E5, A20, FT 3120, 3150®, and FT 3150 chips. 2. INSTALLATION INSTRUCTIONS ============================= WARNING -- SERVICE PACK 4 MAY ONLY BE INSTALLED ON WINDOWS 95 (
