in your I/O driver, define you I/O topic name,
(Ethernet define IP address, Serial port define baud rate)
and in your InTouch application define 2 access name
one is point to topic name of Ethernet, and the other is point to topic name of Serial port.
but if you can used Applicom card only one I/O driver to use.
