LonBuilder / NodeBuilder / 3120 Programmer 更新 点击:1875 | 回复:1
gongkongedit
  • 精华:1099帖
  • 帖子:14392帖 | 54470回
  • 历史总积分:622
  • 注册:2008年9月08日
发表于:2001-08-07 11:42:00
NodeBuilder 1.5 > Service Pack 6 > Posted: July 17, 2001 > Customer Symptom: If using version 12 firmware with any 3150, the load will > fail with an error #4 if including the debugger in the project (#include > ). > Problem: Mistake in the 3150 symbol table file > (c:\Lonworks\images\Ver12\Sys3150.sym) > Fix: Use the new file attached to this email (Sys3150.sym), OR download > Service Pack 7. NB 1.5, Service Pack 7 will be released within the next few > days. Please check the downloads page for the update. > > LonBuilder 3.0 > Service Pack 3 > Posted: July 17, 2001 > Customer Symptom: If using version 12 firmware with any 3150 (on a custom > node, not an emulator), the load will fail with an error (Network Management > Error: Application image inconsistency while going from appl-less/uncfg > state to hard-offline state) if including the debugger in the project > (#include ). > Problem: Mistake in the 3150 symbol table file > (c:\LB\images\Ver12\Sys3150.sym) > Fix: Use the new file attached to this email (Sys3150.sym), OR download > Service Pack 4. LB Service Pack 4 will be released within the next few > days. Please check the downloads page for the update. > > Neuron 3120 Programmer software > NP Version 1.3 > Posted: July 16, 2001 > Customer Symptom: In LB and NB, the customer will see an entry in the HW > Properties window called FT3120F4. > Problem: The files may build without error, but these compilers will not > build them correctly for the upcoming chip (Echelon FT 3120). Therefore, if > they plan to start development for that chip then they need to replace the > Neuron.typ file with a correct version and redefine the hardware template > using the image that says 3120E4 and rebuild. > Fix: The install for this software is the manual copying of files from the > zip to particular directories. The only file that is a problem is > Neuron.typ. I will include the correct version to use, but if the customer > installs the NB or LB service pack, they will get the file from either of > those. PLEASE NOTE that the correct version has an older date than the > incorrect version. The correct modification date for the file is 10/25/00, > NOT 7/13/01. That new file contains information that is not compatible with > LB and NB. It was designed for NB 3, and after these problems, they have > decided to rename the file for NB 3, so neuron.typ is going to disappear > when that product arrives.
gongkongedit
  • 精华:1099帖
  • 历史总积分:622
  • 注册:2008年9月08日
发表于:2001-08-09 09:19:00
Service Pack 7 已经可以下栽了
