LonWorks:学习设计"End to End" 解决方案 点击:1015 | 回复:2
gongkongedit
  • 精华:1099帖
  • 帖子:14392帖 | 54470回
  • 历史总积分:622
  • 注册:2008年9月08日
发表于:2002-01-24 15:51:00
内容来自美国Echelon公司总部培训部(备注:经过编辑) design a working "End to End" Solution In the near future Echelon will add the 10 and 100 models to its i.LON line. These new products will allow our customers to distribute control, management, and design phases of LONWORKs networks through out the world. While this has been possible with the iLon1000 and the SLTA, the new products will make this function easier and cheaper to accomplish. In most instances, we can expect the customer to leverage the accessibility of the internet and the various web technologies. To prepare for future applications and customer interest of distributed control and management we must now look at the tools required to implement such applications in a scalable manner. During this intensive one-day class we will be covering many topics, most of them very quickly and we will expect you come with some understanding of the basics. We will discuss topics such as XML, DOM, DHTML, JScript and many more. We intend to show you how all these Internet/Web tools can be used to design a working "End to End" Solution, from your LonWorks device, thru an i.Lon all the way to your web page, on the other side of the world. To prepare for the class and to get the most from your time we are asking you to do a few hours of Pre-Req reading. We provided Overviews, Primers, or Introductions to each key topic for your convenient reading pleasure, We realize how busy you are, but often you have time to read while flying, or taking the train to work. Therefore we suggest you print and carry the attachments with you. When you are Online to the Internet, you can click on the following links to continue your research and information gathering. DHTML: http://msdn.microsoft.com/library/default.asp?url=/workshop/author/dhtml/dhtml_node_entry.asp DOM http://hotwired.lycos.com/webmonkey/97/32/index1a.html?tw=authoring http://wsabstract.com/javatutors/dom.shtml http://www.w3.org/TR/1998/REC-DOM-Level-1-19981001/expanded-toc.html JavaScript http://www.webteacher.com/javascript/ http://csu.colstate.edu/webdevelop/javascript/jscript/jstutor.htm XML http://www.w3schools.com/xml SOAP http://www.w3schools.com/soap
gongkongedit
  • 精华:1099帖
  • 历史总积分:622
  • 注册:2008年9月08日
发表于:2002-01-24 15:45:00
有关技术文档,请多多关注中国工控网下载中心或者LonWorks论坛。
警察
  • 精华:2帖
  • 帖子:12帖 | 51回
  • 历史总积分:148
  • 注册:2002年1月19日
好东西
