Ethernet: Thick, thin, or UTP? 点击:873 | 回复:3
gongkongedit
  • 精华:1099帖
  • 帖子:14392帖 | 54470回
  • 历史总积分:622
  • 注册:2008年9月08日
发表于:2001-09-16 18:03:00
Ethernet: Thick, thin, or UTP? Thick Ethernet (10Base-5) was the original IEEE 802.3 Ethernet standard. It is called thick or thicknet because its cable consisted of RG-8U coaxial cable similar to that used for cable TV. Thin Ethernet (10Base-2) was the second IEEE Ethernet standard. It is often called thin or thinnet because it used the thinner RG-58 A/U coaxial cable at the same data rate. 10Base-T Ethernet, the most common form today, uses unshielded twisted-pair, or UTP, cable in a star topology.
gongkongedit
  • 精华:1099帖
  • 历史总积分:622
  • 注册:2008年9月08日
发表于:2001-09-16 16:00:00
I think, 10Base-T should be the best Network media for industrial control network.
gongkongedit
  • 精华:1099帖
  • 历史总积分:622
  • 注册:2008年9月08日
pwgea
  • 帖子:6帖 | 207回
  • 历史总积分:204
  • 注册:2001年2月09日
yes ,I hope it is,too.
