发表于:2002-11-26 15:09:00
(1) LNS 3 SP8 Now Available
LNS 3 SP8 was released by Echelon today. LNS 3 SP8 corrects problems
recently reported by
our customers, and Echelon recommends that all end-users and developers who
use LNS 3 based
tools (such as LonMaker 3, LonMaker 3.1, NodeBuilder 3 and numerous
third-party tools)
install LNS 3 SP8.
The LNS 3 SP8 installer and readme are available from
http://www.echelon.com/downloads.
The readme contains installation instructions as well a complete description
of each fixed
problem. The following is the list of problem descriptions:
- Privilege problems with an LNS application running as a Windows service
- Windows XP default folder access does not support Power Users group
- Cant install LNS Remote Client redistribution in 3.07
- Unable to open database, LCA#25 (DB #-2028)
- Some commands to Remote Network Interfaces can hang if the RNI does not
respond
- DataPoint.GetField() did not work properly in 3.07
- DS#34 error when writing to a host Network Variable
- Opening different networks with the same L5 NI causes misleading error
message
- Possible read access violation during System.Open()
- Interface.AddNvFromString() failure cases did not clean up NVs properly
- Memory leak in VNIserver process on Windows XP
- Reference count leaks on Subsystem and NetworkServiceDevice objects
