DCOM 配置 --1 点击:1558 | 回复:1
gongkongedit
  • 精华:1099帖
  • 帖子:14392帖 | 54470回
  • 历史总积分:622
  • 注册:2008年9月08日
发表于:2002-09-19 10:26:00
How to Configure the Client Side • Register your component. • Open the dcomcnfg tool. • In the Applications tab, select your application and click on Properties… button. • Properties -> General tab -> Authentication Level combo box. Select Default. • Properties -> Location tab. Remove selection from Run application on this computer option box, and select Run application on the following computer option box. Click on Browse... button, and select the requested target machine (PC2). • Properties -> Security tab. Select Use custom access permissions option box. Click on Edit button, and then click on Add button, add the following users (Allow Access): o Rebat Hiary o Everyone • Properties -> Security tab. Select Use custom launch permissions option box, click on Edit button, and then click on Add button, add the following users (Allow Launch): o Everyone o Rebat Hiary o PC1/Administrators o System o Interactive • Properties -> Security tab. Select Use custom configuration permission option box, click on Edit button, and then click on Add button, add the following users: o Rebat Hiary o Everyone o System o Creator Owner o PC1/Power Users o PC1/Administrators • Properties -> Identity. Select The interactive user option box. • Click on OK button to return back to the Distributed COM Configuration Properties window. • Default Properties tab. Select Enable Distributed com on this computer check box. • Default Properties tab -> Default Authentication Level combo box. Select Connect. • Default Properties tab -> Default Impersonation Level combo box. Select Anonymous. • Default Security tab. On the Default Access Permissions frame click on Edit Default… btton, click on Add and add the following users (Allow Access): o Everyone o Rebat Hiary • Default Security tab. On the Default Launch Permissions frame click on Edit Default… button, click on Add and add the following users (Allow Launch): o Interactive o PC1/Administrators o System • Default Security tab. On the Default Configuration Permissions frame click on Edit Default… button, click on Add and add the following users: o Rebat Hiary o Everyone o System o Creator Owner o PC1/Power Users o PC1/Administrators • (VERY IMPORTANT) Delete the EXE component from client machine.
月之哀霜
  • 求助:1帖
  • 帖子:1帖 | 19回
  • 历史总积分:4
  • 注册:2016年9月07日
发表于:2017-01-13 15:15:25
