紧急求助!3x 点击:1029 | 回复:1
gongkongedit
  • 精华:1099帖
  • 帖子:14392帖 | 54470回
  • 历史总积分:622
  • 注册:2008年9月08日
发表于:2002-06-27 16:06:00
为什么我的Viewer一运行就自动关闭了? logger里记录出错信息为: Unknown OPCode in GetDValue():2; WC shutting down... WindowClass could not be unregistered,ERROR:0
Johnny
  • 帖子:1帖 | 187回
  • 历史总积分:187
  • 注册:2001年7月27日
WW tracking database ====================== This error is generally associated with application corruptuion, usually in scripts. GetDValue relates to a discrete value, possible a CS based on a discret tag tha6t does not exist or has a bad entry for it. ====================== maybe you can send your intouch application to wonderware or your local distributor, let he/she solve your question.
