提供LNS OPC Server演示版 点击:2065 | 回复:3
gongkongedit
  • 精华:1099帖
  • 帖子:14392帖 | 54470回
  • 历史总积分:622
  • 注册:2008年9月08日
发表于:2002-01-31 21:39:00
提供LNS OPC Server演示版 请到下载中心下载。
gongkongedit
  • 精华:1099帖
  • 历史总积分:622
  • 注册:2008年9月08日
发表于:2002-01-31 14:33:00
该软件目前性能,功能都不错,已经被国外很多集成商采用。2000年我曾经为该公司的软件进行过测试。(现在已经升级到LNS 3.0) Hello,Zhuo Thank you for evaluating our OPC server. NLOPC is not LNS native for performance reasons. We export any LNS database and create our OPC database. So you can use it with any LNS version even 3.0. Regards. Serge LE MEN ---------------------------------------- NEWRON SYSTEM 25 Blvd victor Hugo 31770 COLOMIERS FRANCE ---------------------------------------- www.newron-system.com Serge.LeMen@newron-system.com -------------------------------------------------- Tel: +33 (0)5-61-15-18-45 Fax: +33 (0)5-61-15-16-44 Mobile: +33 (0)6-11-44-33-37 -------------------------------------------------- ----- Original Message ----- From: yizhuo To: sergeLEMEN Sent: Wednesday, September 13, 2000 6:58 AM Subject: 回复: opc help Hello, I tested your LON OPC Server product. In my test LON network design environment ,I used LonMaker for Windows 2.0 and LonPoint Module such as AI-10,AO-10,DI-10,DO-10,etc. With your OPC Server, I have completed OPC Server Configuration ,start OPC server,and link any OPC client software such as Factorysoft ,iFix ,InTouch OPC Link ,etc. This OPC Server is very good. But during testing ,I find the following little error: after I export LNS database to NLC database in OPC Server Configuration, then I push " test database"button, when I click the mouse one or several times on Vertical ScrollBar to explore Lon system in details ,the error appears,indicate illogical operation,then close the windows form. The error as following: SPVNL210 在 0177:0161ba0d 的模块 NL210_32.DLL 中导致例外 10H。 Registers: EAX=00000055 CS=0177 EIP=0161ba0d EFLGS=00010246 EBX=004150e8 SS=017f ESP=0057f94c EBP=00000000 ECX=0000000f DS=017f ESI=01753c94 FS=1c87 EDX=0057005f ES=017f EDI=004150ea GS=0000 Bytes at CS:EIP: dd d8 5f 5e 5d 66 33 c0 5b 59 c3 ae b9 61 01 3c Stack dump: 0041002c 01753c92 00000000 00000011 00410002 016145b4 00000002 01750002 01753c92 004150e8 d503002b 00000001 d503002b 00405b7f 00000000 0041002c At last ,I still have a question about the OPC Server. I want to know whether the NLOPC Server supports LNS Server 3.0 version. The current OPC Server is developed by which LNS verison. If I use LonMaker 2.02,May I use the OPC. Thanks for your help Best Regards Yi Zhuo Beijing Vaton Beijing Friendship Hotel Building No.5 Room 50330 100873 China
SEVA楼宇自控
  • 精华:2帖
  • 帖子:8帖 | 94回
  • 历史总积分:128
  • 注册:2002年1月21日
thanks!
yuhoucaihong
  • 帖子:13帖 | 546回
  • 历史总积分:5061
  • 注册:2003年5月28日
发表于:2006-03-26 17:47:00
能否给我发一份呢
    联系方法:
   邮编:130617 地址:吉林长春市吉林亚泰水泥有限责任公司计控室
   姓名:杨铁锋
信箱:19800929568@sina.com
    谢谢!
