ShortStack API提供的几个函数? 点击:705 | 回复:1
gongkongedit
  • 精华:1099帖
  • 帖子:14392帖 | 54470回
  • 历史总积分:622
  • 注册:2008年9月08日
发表于:2002-01-08 11:20:00
What function calls are provided by the ShortStack API? The ShortStack API provides approximately 10 function calls. The four that you will typically use in your application are the following: void lonInit(void); void lonEventHandler(void); Byte *lonGetNvValue(Byte nvIndex); Bool lonSendNvUpdate(Byte nvIndex, const Byte* pData, Byte len); Additional functions are provided to receive notification of network variable updates, to send and receive application messages, and to send service pin messages.
gongkongedit
  • 精华:1099帖
  • 历史总积分:622
  • 注册:2008年9月08日
是用c语言提供的吗?用pic16f877的话,要用什么工具,是否有hi-tech c支持?
