TRACE MODE®的设备支持 点击:3077 | 回复:0
gongkongedit
  • 精华:1099帖
  • 帖子:14392帖 | 54470回
  • 历史总积分:622
  • 注册:2008年9月08日
发表于:2001-11-06 09:29:00
TRACE MODE®的设备支持 TRACE MODE®可以和各种不同的I/O设备进行数据交换。 1、内置常用I/O设备(如:ADAM4000、ADAM5000/485 NuDAM-6000、I-7000等模块)的驱动程序和通讯协议(如:MODBUS) 2、提供200多种I/O设备的外部驱动程序库 3、开放的I/O驱动程序接口,允许用户使用MS VC++编写DOS和WINDOWS环境下的I/O驱动程序 以下为TRACE MODE所支持常用设备的清单,特殊产品不含在内,同时可根据用户要求免费开发驱动程序: PLC和PC-based控制器 1. ABB Advant; 2. ABB Alfa; 3. Adlink Nudam; (同维工控) 4. Advantech ADAM 4000; (研华) 5. Advantech ADAM 5000 CAN; (研华) 6. Advantech ADAM 5000; (研华) 7. Advantech PCL MIC 2000; (研华) 8. Advantech PCL; (研华) 9. AGE Automation Gmbn; 10. Albatros; 11. Alfa-Laval; 12. Allen Bradley PLC 2; 13. Allen Bradley PLC 3; 14. Allen Bradley PLC 5/250; 15. Allen Bradley PLC 5; 16. Allen Bradley SLC5/04; 17. Analog Devices 6B; 18. ASCON; 19. AspenTech; 20. AutoLog 14 Brick; 21. AutoLog 100 Brick; 22. AutoLog 14; 23. AutoLog 16; 24. AutoLog 20; 25. AutoLog 32; 26. AutoLog 2000; 27. BenchMark (option); 28. BrainWave; 29. Bristol Babcok; 30. Cegelec; 31. Contrex CX1000; 32. Control Microsystems; 33. Cutler Hammer; 34. Elsag Bailey Infi-90 DCS; 35. Emicon EK -2000; 36. Festo; 37. Fisher Rosemount DeltaV; 38. Fisher Rosemount Provox; 39. Fisher Rosemount GCX; 40. Fluid Data Excel V; 41. Foxboro I/A; 42. Foxboro 931; 43. GE Fanuc EPM 3710 TCP/IP; 44. General Electric CCM; 45. General Electric CNP; 46. GENIUS I/O Series 6, 47. GENIUS I/O Series 90; 48. GENIUS I/O Gensym G2; 49. Grayhill; 50. Honeywell APP; 51. Honeywell TDC; 52. Honeywell DPR 3000; 53. ICP-DAS; 54. Jetter; 55. Kloeckner-Moeller; 56. Kompas TM (option); 57. Korat (option); 58. Koyo PLC Direct 105, 59. Koyo PLC Direct 205, 60. Koyo PLC Direct 305, 61. Koyo PLC Direct 405; 62. KR 300 KONTRAST; 63. Kruiz; 64. Lagoon; 65. LAN Automatic; 66. Logika (option); 67. Lomicont 110-122; 68. LON Works; 69. LPS-A-5-01; 70. Micro PC OCTAGON SYSTEMS 5025; 71. Micro PC OCTAGON SYSTEMS 5066; 72. Micro PC OCTAGON SYSTEMS 6012; 73. Micro PC OCTAGON SYSTEMS 6020; 74. Micro PC OCTAGON SYSTEMS 6040; 75. Micro PC OCTAGON SYSTEMS 6050; 76. MiniLAZ; 77. Mitsubishi A, 78. Mitsubishi FX; 79. Modicon Schneider Automation; 80. Modicon TSX Quantum; 81. Modicon; 82. Moore APACS; 83. NAIS FP-series; 84. National Instruments Distributed I/O; 85. OMRON Sysmac way; 86. OMRON Net; 87. Open; 88. Opto22; 89. PEP; 90. Pepperl+Fuchs; 91. Phoenix Contact; 92. Remicont 110 (option); 93. Remicont 120 (option); 94. Remicont 130; 95. RK 131/300 KONTRAST; 96. RPT-80 (option); 97. SH 711/1; 98. SH 711/2; 99. Siemens Profibus H1; 100. Siemens Profibus L2; 101. Siemens S5; 102. Siemens S7; 103. SMAR; 104. SmartWire; 105. SuperFlow; 106. Takebushi Electric; 107. TCS 6382 (option); 108. Technotrade T-box; 109. Tecon MFC; 110. Tecon TCM 21(option); 111. Tecon TCM 52; 112. Tecon TCM51 (option); 113. Telemecanique; 114. Telesafe; 115. Texas Instruments 500/505 series; 116. Toshiba EX100; 117. Toshiba T1; 118. Toshiba T2; 119. Toshiba T3; 120. TREI; 121. Triconex; 122. TwinCAT; 123. Valmet Damatic XD; 124. Valmet; 125. Vortex Microsystems; 126. Vzlet; 127. Yokogawa 2000; 128. Yokogawa Centrum-CS; 129. Yokogawa CS1000; 130. Yokogawa CS 3000; I/O 板卡 1. ADVANTECH MIC 2718; 2. ADVANTECH MIC 2728; 3. ADVANTECH MIC 2730; 4. ADVANTECH MIC 2732; 5. ADVANTECH MIC 2750; 6. ADVANTECH MIC 2752; 7. ADVANTECH PCL 711B; 8. ADVANTECH PCL 711S; 9. ADVANTECH PCL 722; 10. ADVANTECH PCL 724; 11. ADVANTECH PCL 725; 12. ADVANTECH PCL 726; 13. ADVANTECH PCL 727; 14. ADVANTECH PCL 728; 15. ADVANTECH PCL 730; 16. ADVANTECH PCL 731; 17. ADVANTECH PCL 732; 18. ADVANTECH PCL 733; 19. ADVANTECH PCL 734; 20. ADVANTECH PCL 735; 21. ADVANTECH PCL 720; 22. ADVANTECH PCL 813B; 23. ADVANTECH PCL 818; 24. ADVANTECH PCL 836; 25. ICP-DAS A 821; 26. ICP-DAS A 822; 27. ICP-DAS A 823; 28. ICP-DAS A 826; 2
