西门子S7-300/400 PLC中OB块的作用
玻璃的心
2012-07-05 22:02
OB的作用如下:
OB1(Free Cycle)顺序扫描
OB10~OB17(Time-Of-Day Interrupt)时间-日期中断
OB20~OB23(Time-Delay Interrupt)时间延迟中断
OB30~OB38(Cyclic Interrupt)周期性中断
OB40~OB47(Hardware Interrupt)硬件中断
OB55(Status Interrupt)状态中断
OB56(Update Interrupt)升级中断
OB57 (Manufacturer Interrupt)厂商专用中断
OB61~OB64(Synchronous Cycle Interrupt)异步周期中断
OB70(I/O Redundancy Error)I/O冗余错误
OB72(CPU Redundancy Error)CPU冗余错误
OB73(Communication Error)通信错误
OB80(Time Error)时间错误
OB81(Power Supply Error)电源错误
OB82 (Diagnostic Interrupt)诊断中断
OB83(Insert/Remove Interrupt)插/拔中断
OB84(CPU Hardware Fault)CPU硬件错误
OB85(Priority Class Error)优先级错误
OB86(Rack Failure)机架错误
OB87(Communication Error)通信错误
OB88 (Processing Interrupt)过程错误
OB90(Background OB)背景OB
OB100(Warm Restart)暖启动
OB101(Hot Restart)热启动
OB102(Cold Restart冷启动
OB121(Programming Error)编程错误
OB122(I/O Access Error)I/O存储错误
注:OB55,OB56,OB57,OB61,OB62,OB63,OB64,OB81,OB84,OB87,OB88,OB90是NOP(空操作)用户不需要用户不需要修改调用空操作的程序。
