请较大虾们问题: 关于变量标签的,编译时老是出现这个问题!在线等~~ 编译错误 类型 fatal 错误 OID out of sequence.Set [OID]Reset=1 上下文 G:\文件\工程\VARIABLE.DBF
2006-02-28 16:16
这个问题很常见,当你已经定义了很多开关,模拟量的变量并编译后,在添加一些变量时,会遇到这一问题。 你到windows文件夹下,找到citect.ini文件,打开后,把[OID]Reset=0改为[OID]Reset=1,保存后,关闭即可.
2006-02-28 22:44
谢谢这位 水中子 大虾啦! 我为啥在citect.ini文件中找不到[OID]Reset=0呢!望赐教~
2006-03-02 12:23
帮助里搜OID,进入后改为1。
2006-03-16 17:56
大虾帮忙看一下这段程序,分析一下结构,我是菜鸟,多谢了。 Gather_00_log: FUNCTION Gather_00_log() INT Gather_00_Rand; M_00_GL_FLAG = 0; M_00_MAIN_RAND = Rand(32767); WHILE M_00_MAIN_RAND = 0 DO M_00_MAIN_RAND = Rand(32767); END TagWrite("S_00_MAIN_RAND",M_00_MAIN_RAND); Sleep(4); Gather_00_Rand = TagRead("S_00_MAIN_RAND"); M_00_MAIN_CON = TagRead("S_00_MAIN_CON"); IF Gather_00_Rand = M_00_MAIN_RAND AND M_00_MAIN_CON = 3 THEN TagWrite("S_00_MAIN_CON",2); Sleep(35); WHILE BIAOZHI = 1 DO Sleep(5); END(如果BIAOZHI = 1说明有其它井怎在传输采集好的功图文件,所以一直等待到BIAOZHI = 0为止) Tran_00_File(); CONVERT_00_File(); END END FUNCTION Tran_00_File() STRING Clear_Str; BIAOZHI = 1; IF D_COMPUTER_STIME = 1 THEN Clear_Str = "^"c:\SIXNET Tools\Programs\sxlogview.exe^" ^"E:\工程文件\sixnet\S19_1900.6PJ^" -clear -Device=Ethernet -IPaddr=141.0.0.17 -Transfer=^"Trans_S_1900^""; ELSE Clear_Str = "^"c:\SIXNET Tools\Programs\sxlogview.exe^" ^"E:\工程文件\sixnet\S19_1900.6PJ^" -clear -Device=Ethernet -IPaddr=141.0.0.17 -Transfer=^"Trans_C_1900^""; END Exec(Clear_Str,6); Sleep(120); TagWrite("S_00_MAIN_RAND",-1); TagWrite("S_00_MAIN_CON",0); BIAOZHI = 0; END FUNCTION CONVERT_00_File()STRING Log_File_Name,Read_File_Str,Start_Data,Start_Time,Mid_Data,Mid_Time,Write_File_Str; INT HFile_Sxstatus,RECORD_SIZE,End_Flag,Start_Ms,Mid_Ms,Start_Time_Ms,Read_Str_length, Mid_Time_Ms,Period_Sec,i_for; REAL k_00,w_00,t_00,Mid_WeiYi_00; IF D_COMPUTER_STIME = 1 THEN Log_File_Name = "D:\DATA\LOG\LOG_1900_S.csv"; ELSE Log_File_Name = "D:\DATA\LOG\LOG_1900_C.csv"; END ErrSet(1); HFile_Sxstatus = FileOpen(Log_File_Name,"r"); IF HFile_Sxstatus <> -1 THEN Read_File_Str = FileReadLn(HFile_Sxstatus); Read_File_Str = FileReadLn(HFile_Sxstatus); Read_File_Str = FileReadLn(HFile_Sxstatus); Read_File_Str = FileReadLn(HFile_Sxstatus); End_Flag = FileEOF(HFile_Sxstatus); RECORD_SIZE = 1; Start_Data = StrLeft(Read_File_Str,10); Start_Time = StrMid(Read_File_Str,11,8); Start_Ms = StrToInt(StrMid(Read_File_Str,20,3)); Start_Time_Ms = StrToDate(StrMid(Start_Data,0,4)+"-"+StrMid(Start_Data,5,2)+"-"+StrMid(Start_Data,8,2)) + StrToTime(Start_Time); Start_Time_Ms = Start_Time_Ms * 1000 + Start_Ms; DL_TIME_ARRAY_00[0] = Start_Time_Ms; Read_Str_length = StrSearch(20,Read_File_Str,","); PT_ZAI_ARRAY_00[0] = StrToReal(StrMid(Read_File_Str,Read_Str_length + 1,5))*150/32767; WHILE End_Flag <> 1 DO Read_File_Str = FileReadLn(HFile_Sxstatus); End_Flag = FileEOF(HFile_Sxstatus); Mid_Data = StrLeft(Read_File_Str,10); Mid_Time = StrMid(Read_File_Str,11,8); Mid_Ms = StrToInt(StrMid(Read_File_Str,20,3)); Mid_Time_Ms = StrToDate(StrMid(Mid_Data,0,4)+"-"+StrMid(Mid_Data,5,2)+"-"+StrMid(Mid_Data,8,2)) + StrToTime(Mid_Time); Mid_Time_Ms = Mid_Time_Ms * 1000 + Mid_Ms; IF Mid_Time_Ms - Start_Time_Ms > 60000 THEN RECORD_SIZE = 0; Start_Time_Ms = Mid_Time_Ms; Start_Data = Mid_Data; Start_Time = Mid_Time; END DL_TIME_ARRAY_00[RECORD_SIZE] = Mid_Time_Ms; Read_Str_length = StrSearch(20,Read_File_Str,","); PT_ZAI_ARRAY_00[RECORD_SIZE] = StrToReal(StrMid(Read_File_Str,Read_Str_length + 1,5))*150/32767; IF End_Flag = 1 THEN Period_Sec = Mid_Time_Ms - Start_Time_Ms; END RECORD_SIZE = RECORD_SIZE + 1; END FileClose(HFile_Sxstatus); ErrSet(0); END Log_File_Name = "D:\DATA\LOG_1900\" + StrMid(Start_Data,0,4) + "\LOG_1900 " + StrMid(Start_Data,0,4) + "-" + StrMid(Start_Data,5,2) + "-" + StrMid(Start_Data,8,2) + " " + StrLeft(Start_Time,2) + "h" + StrMid(Start_Time,3,2) + "m.csv"; ErrSet(1); HFile_Sxstatus = FileOpen(Log_File_Name,"A"); FileClose(HFile_Sxstatus); HFile_Sxstatus = FileOpen(Log_File_Name,"W"); FileWriteLn(HFile_Sxstatus,"ms of Period:"); FileWriteLn(HFile_Sxstatus,IntToStr(Period_Sec)); FileWriteLn(HFile_Sxstatus,"Size of Record:"); FileWriteLn(HFile_Sxstatus,IntToStr(RECORD_SIZE)); FileWriteLn(HFile_Sxstatus,"WeiYi,PT_ZAI"); FileWriteLn(HFile_Sxstatus,RealToStr(D_00_CC,5,3) + "," + RealToStr(PT_ZAI_ARRAY_00[0],5,2)); k_00 = D_00_QB/D_00_LG; w_00 = (2*Pi())/Period_Sec; FOR i_for = 1 TO RECORD_SIZE - 1 DO t_00 = DL_TIME_ARRAY_00[i_for] - Start_Time_Ms; Mid_WeiYi_00 = (D_00_CC/2)*(1+Cos(w_00*t_00)-(1/k_00)*(1-Sqrt(1-Pow(k_00,2)*Pow(Sin(w_00*t_00),2)))); FileWriteLn(HFile_Sxstatus,RealToStr(Mid_WeiYi_00,5,3) + "," + RealToStr(PT_ZAI_ARRAY_00[i_for],5,2)); END FileClose(HFile_Sxstatus); ErrSet(0); END
