首页 正运动技术 正文
回复
使用正运动控制器读取松下 A6 编码器的例程
正运动技术 浏览:1253 回复:2 收藏
正运动技术  2023-07-25 11:47
本文将使用正运动技术运动控制器实现与松下A编码器进行数据读取操作。
'************************绝对值编码器部分******************************
SETCOM(38400,8,1,0,1,0) '设置 485 口 PORT1 为自定义协议
GLOBAL DIM tempchar '接收的一个字节
GLOBAL DIM neqbuff(2) '发送识别码 485 为 81H,05H
neqbuff(0) = $81
neqbuff(1) = $05
GLOBAL DIM eotbuff(2) '接收识别码 485 为 80H,04H
eotbuff(0) = $80
eotbuff(1) = $04
GLOBAL DIM ackbuff '接收应答 06H
ackbuff = $06
GLOBAL DIM cmdbuff(20) '发送命令数组
GLOBAL DIM getbuff(20) '接收的字符串
GLOBAL DIM getnum '接收的字节数
getnum = 0
GLOBAL DIM highdata '编码器多圈数据
GLOBAL DIM lowdata '单圈数据
runtask 4,get_char '启动接收字符串任务
MODBUS_REG(0)=0
WHILE 1
  IF MODBUS_REG(0)=1 THEN '判断是否接收到了数据
     MODBUS_REG(0)=0
     getmpos(1,45) '读取站号 1 的多圈与单圈值。
  ENDIF
WEND
END
'读坐标
GLOBAL SUB getmpos(sifunum,rcr) '读伺服编号为 1 的电机的绝对值位置
   cmdbuff(0) = $00
   cmdbuff(1) = sifunum
   cmdbuff(2) = $d2
   cmdbuff(3) = rcr
   neqbuff(0) = $80 + sifunum
   neqbuff(1) = $05
   eotbuff(0) = $80
   eotbuff(1) = $04
   getnum = 0
   putchar #1,neqbuff
   TICKS = 2000 '延时
   WAIT UNTIL (getnum = 2) OR TICKS < 0
   IF getnum = 2 THEN '如果接到了 2 个字符
      IF(getbuff(0)=$80+sifunum) AND (getbuff(1)=$04) THEN'收到应答发送命令
         getnum = 0
         PUTCHAR #1,cmdbuff '发送读取编码器命令
         TICKS = 2000
         WAIT UNTIL (getnum = 3) OR TICKS < 0
         IF(getbuff(0) = $06) AND (getbuff(1) = $80) AND (getbuff(2) = $05) THEN'收到发送请求,给应答
             getnum = 0
             PUTCHAR #1,eotbuff '发送应答,等待接收数据
             TICKS = 2000
             WAIT UNTIL (getnum = 15) OR TICKS < 0
             IF getnum = 15 THEN '读到数据 11-10 为多圈数据 9-7 为单圈数据
                PUTCHAR #1,ackbuff
                highdata = getbuff(11) * $100 + getbuff(10)
                lowdata = getbuff(9) * $10000 + getbuff(8) * $100 +getbuff(7)
                PRINT getbuff(11),getbuff(10),getbuff(9),getbuff(8),getbuff(7),getnum
             ELSE
                PRINT getnum,getbuff(0) ,getbuff(1),"超时重新读取 1"
             ENDIF
           ELSE
            PRINT getbuff(0) ,getbuff(1),"超时重新读取 2"
          ENDIF
        ELSE
          PRINT getbuff(0) ,getbuff(1),"驱动器无应答"
        ENDIF
      ELSE
        PRINT "驱动器无应答"
      ENDIF
END SUB
'串口接收
GLOBAL SUB get_char()
   WHILE 1
      GET #1,tempchar
      getbuff(getnum) = tempchar
      getnum = getnum + 1
   WEND
END SUB
我知道了
