首页 威纶通(we. 正文
回复
威纶通宏指令控制红绿灯显示
威纶通(weinview)HMI 浏览:2279 回复:9 收藏
hz118  2021-12-24 14:30
macro_command main()
int i=1,j=0,k=0
int a=0
int t=0,t2=0,t3=0,t4=0
int t1=0,t0=0
int t9=0,d=0,h=0,m=0,s=0
GetData(t9, "Local HMI", LW, 60, 1)
GetData(s, "Local HMI", LW, 100, 1)//红绿灯运行时间秒
GetData(m, "Local HMI", LW, 90, 1)//红绿灯运行时间分
GetData(h, "Local HMI", LW, 80, 1)//红绿灯运行时间时
GetData(d, "Local HMI", LW, 70, 1)//红绿灯运行时间日
t9=t9+1
m=t9/60
s=t9%60
h=m/60
m=m%60
d=h/24
h=h%24
SetData(s, "Local HMI", LW, 100, 1)
SetData(m, "Local HMI", LW, 90, 1)
SetData(h, "Local HMI", LW, 80, 1)
SetData(d, "Local HMI", LW, 70, 1)
SetData(t9, "Local HMI", LW, 60, 1)
GetData(t, "Local HMI", LW, 20, 1)
GetData(t0, "Local HMI", LW, 50, 1)
t=t+1//红绿灯运行一个周期时间39秒
SetData(t, "Local HMI", LW, 20, 1)
if 0<t and t<20 then
t0=t0+1//为方便减计时增加t0
SetData(t0, "Local HMI", LW, 50, 1)
GetData(t1, "Local HMI", LW, 30, 1)
t1=19-t0
SetData(t1, "Local HMI", LW, 30, 1)
//红灯1亮计时显示
if t0==19 then
t0=0
end if
SetData(i, "Local HMI", LW, 0, 1)
else
SetData(j, "Local HMI", LW, 0, 1)
end if//红灯1亮19秒
if 0<t and t<16 then
GetData(t2, "Local HMI", LW, 26, 1)
t2=15-t0
SetData(t2, "Local HMI", LW, 26, 1)
//绿灯1亮计时显示
SetData(i, "Local HMI", LW, 8, 1)
else
SetData(j, "Local HMI", LW, 8, 1)
end if//绿灯1亮15秒
if 15<t and t<20 then
SetData(i, "Local HMI", LB, 10, 1)
else
SetData(j, "Local HMI", LB, 10, 1)
end if//黄灯1闪烁
if 19<t and t<40 then
GetData(t3, "Local HMI", LW, 24, 1)
t3=39-t
SetData(t3, "Local HMI", LW, 24, 1)
//红灯2亮计时显示
SetData(i, "Local HMI", LW, 6, 1)
else
SetData(j, "Local HMI", LW, 6, 1)
end if//红灯2亮19秒
if 19<t and t<36 then
GetData(t4, "Local HMI", LW, 22, 1)
t4=35-t
SetData(t4, "Local HMI", LW, 22, 1)
//绿灯2亮计时显示
SetData(i, "Local HMI", LW, 2, 1)
else
SetData(j, "Local HMI", LW, 2, 1)
end if//绿灯2亮15秒
if 35<t and t<40 then
SetData(i, "Local HMI", LB, 4, 1)
else
SetData(j, "Local HMI", LB, 4, 1)
end if//黄灯2闪烁
if t==39 then
t=0
end if
end macro_command
正在下载,请等待……
下载附件需 1 积分!
我知道了
