首页 ABB机器人 正文
回复
ABB在视觉开发Socket接收数据如何处理的两种方法
ABB机器人 浏览:989 回复:5 收藏
liyanbin  2021-10-22 11:09
第一种方法:按位分割
PROC SocketServer()
     VAR socketdev server_socket1;
     VAR socketdev client_socket1;
     VAR string client_ip:="10.70.2.240";客户端的IP地址
     VAR string receive_string;
     VAR string string_j1:=""; 定义用于分割取位后存储字符的字符串
     VAR string string_j2:="";
     VAR string string_j3:="";
     VAR string string_j4:="";
     VAR string string_j5:="";
     VAR string string_j6:="";
     VAR num num_j1:=0;定义将取位后的字符串转换成值类型的数据存储
     VAR num num_j2:=0;
     VAR num num_j3:=0;
     VAR num num_j4:=0;
     VAR num num_j5:=0;
     VAR num num_j6:=0;
     VAR bool change_ok:=false; 转换标志位
     VAR robtarget current_position_robT; 定义robtarget类型的坐标点
     VAR jointtarget current_position_jointT; 定义jointtarget类型的坐标点
               SocketClose server_socket1;
        SocketClose client_socket1;
        SocketCreate server_socket1;
        SocketBind server_socket1," 10.70.2.252",3000;机器人端IP地址和端口
        SocketListen server_socket1;
        SocketAccept server_socket1,client_socket1\ClientAddress:=client_ip\Time:=WAIT_MAX;
         WHILE TRUE DO
            SocketReceive client_socket1\str:=receive_string\Time:=WAIT_MAX;
!            TPWrite "receive_string="+receive_string;
!            SocketSend client_socket1\Str:="Hello World";
         string_j1:=StrPart(receive_string,1,6);对接收的字符串按位分割,每6位为一组坐标(例:-321.1保留两位小数,正好可以满足机器人坐标数据使用。)
         string_j2:=StrPart(receive_string,7,6);7位开始的6个字符串
         string_j3:=StrPart(receive_string,13,6); 13位开始的6个字符串
         string_j4:=StrPart(receive_string,19,6); 19位开始的6个字符串
         string_j5:=StrPart(receive_string,25,6); 25位开始的6个字符串
         string_j6:=StrPart(receive_string,31,6); 31位开始的6个字符串
         change_ok:=StrToVal(string_j1,num_j1);!j1将接收的字符串转换为值类型的数据(值可以是整数也可以是小数)
         change_ok:=StrToVal(string_j2,num_j2);!j2
         change_ok:=StrToVal(string_j3,num_j3);!j3
         change_ok:=StrToVal(string_j4,num_j4);!j4
         change_ok:=StrToVal(string_j5,num_j5);!j5
         change_ok:=StrToVal(string_j6,num_j6);!j6
         current_position_robT:= CRobT(\Tool:=tool1\wobj:=wobj1);获取当前坐标点的数据赋值给current_position_robT点位。
         current_position_jointT:=CalcJointT(current_position_robT,tool1 \WObj:=wobj1);robtarget型数据转换为jointtarget        current_position_jointT:=Absjoffs(current_position_jointT,num_j1,num_j2,num_j3,num_j4,num_j5,num_j6);赋值函数
               MoveAbsJ current_position_jointT\NoEOffs, v1000, fine, tool1;
        ENDWHILE
       ENDPROC
        FUNC jointtarget Absjoffs(jointtarget Point,num j10ffset,num j20ffset,num J30ffset,num J40ffset,num J50ffset,num J60ffset) 偏移函数
        VAR jointtarget joint_temp;
        joint_temp:=Point;
        joint_temp.robax.rax_1:=joint_temp.robax.rax_1+J10ffset;对轴数据进行赋值。
        joint_temp.robax.rax_2:=joint_temp.robax.rax_2+J20ffset;
        joint_temp.robax.rax_3:=joint_temp.robax.rax_3+J30ffset;
        joint_temp.robax.rax_4:=joint_temp.robax.rax_4+J40ffset;
        joint_temp.robax.rax_5:=joint_temp.robax.rax_5+J50ffset;
        joint_temp.robax.rax_6:=joint_temp.robax.rax_6+J60ffset;
        RETURN joint_temp;
ENDFUNC
第二种方法是基于第一种的基础改编。
PROC SplitStr( string inputstr,string sp,inout string data{*})
字符串分割函:inputstr输入字符串,sp分割符,data{*}存入数据的数组
              VAR string s1;
        VAR string s2;
        VAR num count:=1;
        VAR bool flag1;
        FOR i FROM 1 TO StrLen(inputstr) DO    循环遍历输入字符串
            s1:=StrPart(inputstr,i,1);            每次取一位分割符字符
            IF s1=sp THEN
               flag1:=StrToVal(s2,data{count});
如果当前字符是分隔符,则将之前的字符串转化为数据并存入data{count}
               s2:="";
               Incr count;
            ELSE
                s2:=s2+s1;          如果当前字符不是分割字符,则字符串拼接
            ENDIF
        ENDFOR
ENDPROC
我知道了
