首页 普洛菲斯(p. 正文
回复
Pro-face编程电缆CA3-USBCB-01驱动程序
普洛菲斯(pro-face)HMI 浏览:1883 回复:8 收藏
江湖再见-余辉  2017-07-31 09:16
操作系统:Windows® 2000 Service Pack 4; Windows® XP
支持软件:GP-Pro EX - all versions
Installation Procedure
Prior to installation, be sure to close all software applications that are running.
1. Click on the link "CA3-USBCB-01Driver.zip" in the table above to download the file to the desired folder.
2. After the download is finished, double-click on the "CA3-USBCB-01Driver.zip" file to open it.
3. Designate a directory to extract (unzip) the file, and then click OK.
4. The driver will be saved in the "CA3-USBCB-01Driver" folder created in the designated directory.
5. After extracting, connect the USB screen transfer cable (CA3-USBCB-01) to a USB port on the PC..
6. After "Found New Hardware Wizard" is displayed, follow the installer‘s instructions to complete installation. (choose "CA3-USBCB-01Driver" folder created in the procedure No. 4)
7. Confirm the installation using the following procedures:
1. Right-Click on "My Computer" and choose "Properties".
2. Choose the "Hardware" tab and then click "Device Manager".
3. Double-click "Universal Serial Bus Controllers"
4. "USB Link Cable (CA3-USBCB-01)" will be in the list if the driver is installed properly.
希望可以帮到有需要的朋友!
正在下载,请等待……
下载附件需 2 积分!
1分不嫌少!
已有1人打赏
我知道了
