现场总线资料参考 点击:8871 | 回复:4
gongkongedit
  • 精华:1099帖
  • 帖子:14392帖 | 54470回
  • 历史总积分:622
  • 注册:2008年9月08日
发表于:2002-05-27 10:36:00
GENERAL Sites http://www.linux-automation.de/fieldbusses/index_en.html http://www.ict.tuwien.ac.at/komzent/index.html http://www.knowthebus.org (Center for fieldbus technological education) http://www.hurray.isep.ipp.pt/index2.asp (Lots of info!) http://www.lpr.e-technik.tu-muenchen.de/courses/seminar/fieldbus/fieldbus.html http://www.shipstar.com/bus-perf/bus-perf.html (No longer exists?) http://read-out.net/signpost/fjnews.html http://www.relcominc.com http://www.fieldbus.net http://www.artemisnetworks.com http://fieldbus.feld.cvut.cz (Chech site) http://www.cs.cmu.edu/~koopman/comm.html http://www.fieldbus.no http://www.iceweb.com.au http://fieldbus.isa.org http://www.isbe.ch/~wwwfbus http://www.bve.nl/bustechnologie/leermiddelen (Dutch site) http://www.fieldbuswiring.com http://www.synergetic.com/education http://www.smar.com http://www.easydeltav.com/keytechnologies/fieldbus/index.asp http://cran.esstin.u-nancy.fr/CRAN/Cran/ESSTIN/FieldBus.html (Outdated, and often unreachable) http://www.fieldbus.com (No longer contains fieldbus information) http://www.infoside.de/infida/wissen2.htm (Outdated) Literature Berge J.,"Fieldbuses for Process Control: Engineering, Operation, Maintenance". ISA Press 2002, ISBN 1-55617-760-7. Black U., "Physical Level Interfaces and Protocols". IEEE, ISBN 0-8186-8824-6. Black U., "The V-series recommendations". McGraw-Hill, ISBN 0-07-005592-0. Bonfig K., "Feldbus-Systeme". Expert Verlag 1992, 3-8169-0771-7. Borst W., "Der Feldbus in der Maschinen- und Anlagentechnik". Franzis Verlag, ISBN 3-7723-4621-9. British Standard Institute, "Guide to the evaluation of fieldbus protocols". Report DISC PD0014:2000. Brown, "The OSI Dictionary of acronyms". McGraw-Hill 1993, ISBN 0-07-057601-7. Burton, "Fieldbus for Industrial Control Systems". Chapmann & Hall 1997, ISBN 0-412-57890-5. Centrum voor Micro-elektronica, "Intelligente sensornetwerken". 1993, 1996 Control Engineering, issues of 1994 and 1995, "Fieldbus series". ETG Fachbericht 37, "Datenübertragung auf Fahrzeugen mittels serieller Bussysteme". VDE Verlag, ISBN 3-8007-1829-4. ETZ Report 27, "Standardisierung der Prozeßdatenkommunikation". VDE Verlag 1991. Fachzeitschrift DE, "Bussysteme für die Gebäudeinstallation. Hüthig & Pflaum, 1999. Färber, "Bussysteme - parallele und serielle Bussysteme in Theorie und Praxis". Oldenbourg Verlag, ISBN 3-486-28581-5. Frankort, "Digitale Communicatie". Delta Press 1989, ISBN 90-6674-726-9. Gladdis, "How to automate your home". Baran-Harper 1991, ISBN 0-9632170-0-3. Gruhler, G. "Feldbusse und Geräte-Kommunikationssysteme". Franzis Verlag 2001, ISBN 3-7723-5745-8. Hill, "A distributed control & diagnostic architecture for railway maintenance". University of South-Carolina 1998. Holzmann, "Design and validation of computer protocols". Prentice-Hall, ISBN 0-13-539834-7. Huber J.,"Industrial Fiber Optic Networks". ISA Press 1995, ISBN 1-55617-521-3-G. Hulsebos, R., "Veldbussen". Kluwer 1996, ISBN 90-557-6059-5. IEE, "Colloquium: Fieldbus devices - A changing future". IEE 1994, Ref. 1994/236. ISA, "Fieldbus Standard for use in industrial control systems". ISA 1993, ISBN 1-55617-317-2. ISA, "The ISA Fieldbus Guide". ISA 1997, ISBN 1-55617-637-6. Johannsmeyer, "Investigation into the intrinsic safety of fieldbus systems (FISCO)". PTB, report W53, ISBN 3-89429-310-1. Jordan, "Serial networked field instrumentation". Wiley 1995, ISBN 0-471-95236-1. Keithley Instruments, "Demanding measurements on the factory floor". Kluwer, "Handboek Industriële Netwerken". Kluwer 2000, ISBN 90-5404-628-7. Kriesel, "Bustechnologien für die Automation, 2nd Ed.". Hüthig Verlag 2000, ISBN 3-7785-2778-9. Lian, "Performance evaluation of control networks for manufacturing systems". Proceedings of the ASME (Dynamics and Control Division), 1999. Miklovic, "Real-time control networks". ISA 1993, ISBN 1-55617-231-1. Mikrocentrum
gongkongedit
  • 精华:1099帖
  • 历史总积分:622
  • 注册:2008年9月08日
Linux driver) http://www.ietf.org/internet-drafts/draft-cafi-can-ip-00.txt (CAN-Over-IP spec) http://www.ixxat.de http://www.port.de http://www.vector-cantech.com http://www.pandora.ist.utl.pt/CAN http://www.ems-wuensche.com http://home.wanadoo.nl/arnaud/links.html (Linux driver) http://www.infineon.com/products/micro/micro.htm Literature Lawrenz, "CAN: Grundlagen und Praxis, 4th Ed.". Hüthig Verlag 2000, ISBN 3-7785-2780-0. Lawrenz, "CAN System Engineering", translation of the German 2nd edition. Hüthig Verlag 1997, ISBN 0-387-94939-9. Haus der Technik e.V., "CAN und andere Autobus-Netzwerke für Industriesteuerungen". Veranstaltungsnummer E-10-940-075-3. Praxis Profiline, "Controller Area Network". Vogel Verlag, ISBN 3-8259-1902-1. Etschberger, "Controller Area Network," 3rd edition (German). Hanser Verlag 2000, ISBN 3-446-19431-2. Etschberger, "Controller Area Network (English). Ixxat 2001, ISBN 3-00-007376-0. Engels, "CAN-Bus Technik: Einfach, anschaulich und praxisnah vorgestellt". Franzis Verlag 2000, ISBN 3-7723-5145-X. Paret, "Le bus CAN - De la théorie et la practique". Dunod 1995, ISBN 2-10003164-3. Paret, "Le bus CAN - Applications (CAL, CAN/Open, DeviceNet, OSEK, SDS, CAN Kingdom)". Dunod, ISBN 2-10003659-9. Mailing list There are two mailing lists; the first at http://groups.yahoo.com/group/CANbus (this is the well-known Vector mailing list), and the second is at www.can-cia.de/board.htm Background CAN is only a small part of a complete network protocolstack. Since there was no standard-setting organisation or company during the early 90s, many companies developed their own and this is the reason why there are about three dozen incompatible protocols, such as: CAN/Open, DeviceNet, CAN Kingdom, SDS, SeleCAN, CAL, M3S, LBS, etc. CONTROLNET User Group Also known as: DD 241, EN 50170/A3, Ethernet/IP (upper layer protocol only), IEC 61158 Type 2 ControlNet International PMB 315 20423 State Road 7 #F6 Boca Raton, FL 33498-6797 (USA) Tel. +1-561-477-7966 Fax. +1-561-477-6621 Email controlnet@powerinternet.com Sites http://www.controlnet.org http://www.ab.com/networks http://home.att.net/~rongage/cell/ CURRENT LOOP Sites http://www.bb-elec.com/technical_library.asp DALI See Digitally Addressable Lighting Interface DATA HIGHWAY Sites http://www.theautomationbookstore.com http://www.ab.com/manuals/cn DC-BUS User Group DC-Bus Alliance (DCBA) Email peter.braun@iqbattery.com Sites http://www.yamar.com DD 241 See Controlnet DEVICE LANGUAGE MESSAGE SPECIFICATION User Group Also known as: DLMS DLMS User Association (DLMS-UA) Pre-de-la-Fontaine 19 1217 Meyrin-Geneva (CH) Tel. +41-22-9809800 Fax. +41-22-9809809 Email dlms@dlms.com Sites http://www.dlms.com http://www.kemaconnect.nl DEVICENET User Group Also known as: Compobus/D, EN 50325/2, IEC 62026/3, SEMI E54.4 Open DeviceNet Vendor Association, Inc. (ODVA) PMB 499 20423 State Road 7 #F6 Boca Raton, FL 33498-6797 (USA) Tel. +1-954-340-5412 Fax. +1-954-340-5413 Email odva@powerinternet.com Sites http://www.odva.org http://www.odvaeurope.com http://www.ricauto.com/library/techinfo http://www.tangskingdom.com/xiong/ http://www.warwick.ac.uk/devicenet DF-1 Sites http://www.ab.com/manuals/cn/protocol.html DIAS See Distributed Intelligent Actors And Sensors DIGITALLY ADDRESSABLE LIGHTING INTERFACE User Group Also known as: DALI, EN 60229, IEC 929 DALI AG http://www.dali-ag.org/ Sites http://www.philips.de/licht/oem_setmakers/technik/dali/dali.htm http://www.lampsandgear.philips.com/press11.shtml Background DALI is a development of the companies Helvar, Huco, Philips, Osram, Tridonic, Trilux and Vossloh-Schwabe. It is a standard for a communications protocol for control of electronic lighting ballasts (dimming controls). It is designed exclusively for lighting purposes, and meets specific needs that are not satisfied by more complex bus systems. A DALI system consists of up to 64 ballasts connected along a twisted-pair cable, and a DALI controller. Maximum network size is 300 meter, and thus suitable for mid-size rooms and standalone systems. Sixty-four unique ballasts can be identified, and sixteen groups of ballasts. DALI messages consist of 1 start bit, 8 address bits, 8 databits, and 2 stopbits. A reply consists of 1 startbit, 8 databits, and 2 stopbits. Typical network commands are "Set light level", "Go to minimum level", "Turn lamp off", "Set light at predefined level", "Return light level", and "Return status". Light levels are specified via a logarithmic regulation curve, running from 0.1% to 100%, specified in an 8 bit number. Operating parameters can be changed and stored dynamically in the ballasts memory, i.e. sixteen different light levels, fade time, fade rate, minimum light level, maximum light level, actual light level. Diagnostics include the status of each ballast and lamp. DIN 9-484 See Landwirtschaftliches Bus System German standard. DIN 19-245 See Profibus German standard, now superseded by the EN 50170/2. Background This norm consists of four parts. DIN 19-245/1 describes the Profibus/FDL (Fieldbus Data Link) protocol; DIN 19-245/2 describes the Profibus/FMS (Fieldbus Messaging Specification) protocol; DIN 19-45/3 describes Profibus/DP (Decentralized Periphery); and DIN 19-245/4 describes Profibus/PA (Process Automation). DIN 19-258 See Interbus-S German standard. DIN 26-050 See European Petrol Station Interface German standard. DIN 32-795 See Firmenneutrales Daten Uebertragungs Protokoll German standard. DIN 56-930 See DMX-512 German standard. DIN 61-491 See Sercos German standard. DIN 66-348 See DIN Measurement Bus German standard. DIN MEASUREMENT BUS User Group Also known as: DIN 66-348 Anwendervereinigung "Din-Messbus e.V. (ADM) Appelstrasse 9A 30167 Hannover (D) Tel. +49-511-762-4673 Fax. +49-511-762-3917 Email wagner@geml.uni-hannover.de Sites http://www.infoside.de/infida/dinmess/measure.htm http://www.iwq.de http://www.measurement-bus.de Literature Rose, "Din-Meßbus: Grundlagen und Praxis". Hüthig Verlag 1994, ISBN 3-7785-2305-8. Rose, "Prozeßautomatisierung mit DIN-Meßbus und Interbus-S". Hüthig Verlag, ISBN 3-7785-2217-5. DISTRIBUTED INTELLIGENT ACTORS AND SENSORS Sites Research project. Also known as: DIAS http://cabernet.esprit.ec.org/esp-syn/text/2172.html DISTRIBUTED NETWORK PROTOCOL User Group Also known as: DNP DNP Users Group PObox 43075, DVPO Calgary, Alberta T2J 7A7 (CA) Fax. +1-403-271-1319 Email dnp@home.com Sites http://www.dnp.org http://www.trianglemicroworks.com DISTRIBUTED SYSTEMS INTERFACE User Group Also known as: DSI. None known. Sites http://www.mot-sps.com/automotive/mottrw.html DISTRIBUTION LINE MESSAGE SPECIFICATION See Device Language Message Specification Abbreviation changed. DLMS See Device Language Message Specification DMX-512 User Group Also known as: DIN 56-930, IEC 62136. DMX=Digital Multiplexing (there is also an AMX). None known. Sites http://www.culturenet.ca/usitt/DMX/DMX512.htm http://www.soundlight.de DNP See Distributed Network Protocol DRIVECOM User Group Drivecom Nutzergruppe e.V. Postfach 1102 32817 Blomberg (D) Tel. +49-5235-341864 Fax. +49-5235-341862 Email webmaster@interbusclub.com Sites http://www.drivecom.org DSF 21906 See P-Net Danish standard. DSI See Distributed Systems Interface EBUS See Energy Bus EHS See European Home System EIA 422 / EIA 485 See RS-422 / 485 EIA 709.1 See Local Operating Network EIA 776 See European Installation Bus EIAMUG See European Intelligent Actuation And Measurement EIB See European Installation Bus ELCOM See TASE.1 EN 50090 See European Installation Bus European norm. EN 50170 Part 1: See P-Net European standard. Part 2: See Profibus Part 3: See Factory Instrumentation Protocol Addendum A1: See Foundation Fieldbus Addendum A3: See Controlnet Background In 1993 CENELEC (European Committee for Electrotechnical Standardization) ordered the working group TC65CX to develop a European fieldbus standard. As usual, no agreement could be reached on which existing systems would become “the” European standard, so a compromise was reached by including several incompatible systems into one standard: the German Profibus (DP and FMS), the Danish P-Net, and the French WorldFIP. In autumn 1995 there was the first voting for the standard. At first the standard was rejected because Finland, Ireland, Norway, Sweden and the United Kingdom voted against it. In March 1996 there was a second round of voting and the rules for standardisation were changed so that to get a fieldbus standard accepted only 51% of countries would have to vote yes (18 countries). This gave those three fieldbuses an opportunity to become a standard even if 17 countries voted against them. The standard became accepted in December 1996. Attempts of other fieldbus systems (such as Interbus) to get incorporated in the EN 50170 failed, and this led to several other EN-standards. Later, ControlNet and Foundation Fieldbus were added to the standard, allegedly to thank the US for their support of including Profibus in the IEC 61158 standard. EN 50254/1 See Interbus-S European norm. EN 50254/2 See Profibus European norm. EN 50254/3 See Factory Instrumentation Protocol European norm. EN 50295 See Actuator-Sensor Interface European norm. EN 50325/2 See Devicenet European norm. EN 50325/3 See Smart Distributed System European norm. EN 50325/4 See Controller Area Network European norm. For CAN/Open only. EN 60929 See Digitally Addressable Lighting Interface European norm. EN 61491 See Sercos European norm. ENERGY BUS User Group Also known as: E-Bus User Club E-Bus e.V. c/o Fachhochschule Braunschweig/Wolfenbüttel Salzdahlumer Straße 46/48 38302 Wolfenbüttel (D) Tel. +49-5331-939624 Fax. +49-5331-939641 Email info@ebus.de Sites http://www.ebus.de ENV 1805-1 See Firmenneutrales Daten Uebertragungs Protokoll European pre-norm. Background Since there is no longer a market demand, CEN/TC247 has recommended the withdrawal of this standard. ENV 1805-2 See Building Automation Control Network European pre-norm. ENV 13154-2 Part 1: See European Installation Bus European pre-norm. Part 2: See European Home System Part 3: See Batiment Intelligent Bus Part 4: See Local Operating Network ENV 13321-1 Part 1: See Profibus/FMS European pre-norm. Part 2: See FIP Part 3: See Building Automation Control Network ENV 13321-2 See European Installation Bus European pre-norm. EPSI See European Petrol Station Interface ETHERNET User Groups Industrial Automation Open Networking Alliance (IAONA-EU) Universitatsplatz 2 39106 Magdeburg (D) Tel. +49-391-6711828 Fax. +49-391-6712404 Email info@iaona-eu.com Industrial Ethernet Association 2506 Wisconsin Avenue Downers Grove, IL 60515 (USA) Fax. +1-630-434-1987 Email webmaster@industrialethernet.com Sites http://www.ots.utexas.edu/ethernet http://www.industrialethernet.com http://grouper.ieee.org/groups/802/3 http://ethernet.industrial-networking.com http://www.industrial-ethernet.com http://www.ethernet.for-industry.com http://www.ethernetio.com http://www.transparentfactory.com http://www.hirschmann-usa.com/an/default.asp http://www.iaona.com http://www.anixter.com/industrial http://www.managetherealworld.com http://www.ab.com/networks/enetpaper.html http://www.ccontrols.com/extension.htm http://www.rjlnxx.com http://www.private.org.il/tcpip_rl.html http://ethereal.zing.org Literature Furrer, "Ethernet TCP/IP für die Industrieautomation", 2nd Ed. Hüthig Verlag 2000, ISBN 3-7785-2779-3. Sink P.,"Industrial Ethernet: A Pocket Guide". ISA Press 2002, ISBN 1-55617-774-7-G. Spurgeon C., "Ethernet: the definitive guide". OReilly 2000, ISBN 1-56592-660-9. Vogel Verlag, "Ethernet in der Fertigung". Praxis Profiline 2000, ISBN 3-8259-1908-0. Vogel Verlag, "Industrial Ethernet: Informationstechnologie in der Automatisierung". Vogel Verlag 2000, ISBN 3-8259-1908-0. Mailing list Look for the "industrialethernet" maillist at www.onelist.com. Magazines The "Ethernet Book" at www.industrial-networking.com. Courses by the author In cooperation with the Mikrocentrum in Eindhoven we host a course on industrial Ethernet, TCP/IP and embedded webservers. Duration is 1 day. Language Dutch. The course is given December 5th (Eindhoven) and 12th (Utrecht); contact e.putte@mikrocentrum.nl for more information. ETHERNET INDUSTRIAL PROTOCOL User Group Also known as: Ethernet/IP Via Open Devicenet Vendors Association Sites http://www.ethernet-ip.org http://www.odva.org EUROMAP Sites http://www.euromap.org EUROPEAN HOME SYSTEM User Group Also known as: EHS, ENV 13154-2 European Home Systems Association (EHSA) Sites http://www.ehsa.com http://www.trialog.com Literature Kung, "The EHS European Home Systems Network". Trialog. Published directly by Trialog and only available via them (email: ehs@trialog.com) Kung, "La Domotique Appliquée avec le Réseau Européen EHS. Trialog, ISBN 2-84180-055-5. EUROPEAN INSTALLATION BUS User Group Also known as: EIB, ANSI 776, EIA 776, ENV 13321-2, ENV 13154-2, EN 50090, I-Bus, Instabus EIB Association (EIBA) Twinhouse, Neerveldstraat 105 1200 Brussel (B) Tel. +32-2-775-8646 Fax. +32-2-675-5028 Email eiba@eiba.com Vereniging EIBA Nederland p/a FME/CWM Postbus 190, 2700 AD Zoetermeer Tel. +31-79-3531273 Fax. +31-79-3531365 Email postmaster@eiba.nl Sites http://www.eiba.com http://www.eiba.de http://www.eib-home.de http://home.t-online.de/home/ibk-neuhof/homepage.htm http://www.eib-forum.de http://www.eibuc.ch http://www.eibnews.de Literature BFE, "Lernprogramm Europäischer Installationsbus". Vogel Verlag 1998, ISBN 3-8023-1783-X. BFE, "European Installation Bus". Vogel Verlag 1999, ISBN 3-8023-1868-4. Dietrich, EIB: Gebäudebussystem. Huthig 2000, ISBN 3-7785-2795-9. Rose, "Gebäudesystemtechnik im Wohn- und Zweckbau mit dem EIB". Huthig 2000, ISBN 3-7785-2643-X. Frank, Der europäische Installationsbus". Verlag Technik 2000, ISBN 3-34101-249-4. Seip, Gebäudesystemtechnik mit EIB. Wiley 2000, ISBN 3-89578-076-6. Leidenroth, "EIB Praxis: Standardfunktionen und ihre Programmierung". Verlag Technik 1997, ISBN 3-341-01180-5. Leidenroth, "EIB Anwenderhandbuch: Planung, Projektierung, Inbetriebname, Kundenberatung". Verlag Technik 1999, ISBN 3-341-01226-5. Jeanrond, "EIB Gebäudesystemtechnik: Die zukunftssichere Elektroinstallation". Pflaum Verlag 1996, ISBN 3-79050-712-1. Scherg, "EIB planen und installieren". Vogel Verlag 1998, ISBN 3-80231-746-7. Rose, "Gebouwsysteemtechniek met de Europese Installatie Bus". Kluwer Techniek 1997, ISBN 90-5576-037-4. (Dutch) Vogel Verlag, "EIB 2.0 Lern-CDROM". Vogel Verlag, 2000. ZVEI, "Gebäudesystemtechnik: Grundlagen (4. Auflage)". ZVEI, 1997. ZVEI, "Gebäudesystemtechnik: Anwendungen (4. Auflage)". ZVEI, 1997. Siemens, "Gebäudesystemtechnik mit EIB". ISBN 3-89578-076-6. Magazines http://www.bussysteme.de EUROPEAN INTELLIGENT ACTUATION AND MEASUREMENT Sites Research project. Also known as: EIAMUG http://cabernet.esprit.ec.org/esp-syn/text/8244.html EUROPEAN PETROL STATION INTERFACE User Group Also known as: EPSI EPSI Development & Improvement Project DGMK/PTB 463 Postfach 540139 10042 Berlin (D) Tel. +49-30-6441587 Fax. +49-30-6441586 Email epsi@berlin.ptb.de Sites http://epsi.berlin.ptb.de http://www.iwq.de FACTORY INSTRUMENTATION PROTOCOL See FIP FICIM See Fieldbus Integration Into CIM FICOMP See Fieldbus Components FIELDBUS COMPONENTS User Group Research project. Also known as: FICOMP http://cabernet.esprit.ec.org/esp-syn/text/6526.html FIELDBUS INTEGRATION INTO CIM Sites Research project. Also known as: FICIM http://cabernet.esprit.ec.org/esp-syn/text/5206.html http://herkules.oulu.fi/isbn9514257855/html/chapter4.html#AEN741 FIELDBUS INTERNET PROTOCOL See FIP FIP / WORLDFIP User Group Also known as: Fieldbus Internet Protocol, Factory Information Protocol, Flux Information Processus, EN 13321-1, EN 50170/3, EN 50254/3, IEC 61158 Type 7 WorldFIP Headquarters 23-25 Avenue Morane Saulnier 92364 Meudon La Foret Cedex (F) Tel. +33-1-4629-1780 Fax. +33-1-4629-1785 Email wfinfo@worldfip.imaginet.fr Sites http://www.worldfip.org http://nicewww.cern.ch/sl/rfgroup/fip FIREWIRE User Group Also known as: IEEE 1394, I-Link 1394 Trade Association (1394TA) 1111 South Main Street, Suite 122 Grapevine, TX 76051 (USA) Tel. +1-817-410-5750 Fax. +1-817-410-5752 Email jsnider@1394ta.org Sites http://www.1394ta.org http://www.zayante.com http://grouper.ieee.org/groups/1394 http://www.andygrove.com/technology/1394/papers.htm http://www.ti.com/sc/1394 Literature Anderson, "Firewire System Architecture". Addison-Wesley 1998, ISBN 0-201-48535-4. FIRMENNEUTRALES DATEN UBERTRAGUNGS PROTOKOLL User Group (Company-neutral datatransfer protocol) None known. Also known as: DIN 32-795, ENV 1805-1, FND Sites http://www.fnd-forum.de Background The FND was developed with German goverment funding in 1988, and because of this the German government required its use on public projects. FND is designed to interconnect "islands of automation" (i.e. complete systems) with supervisory computers. It only specifies a common interface to the data network itself, which may be implemented using any, relatively high-speed technology. The protocol specifies in its application layer general data items and functional properties of these data items. The general data items defined in the FND application layer are the point objects, analogue inputs, analogue outputs, digital inputs, digital outputs, setpoints, multi-state inputs and multi-state outputs. Further installation of FND systems is expected to be limited to the extension of existing installations in Germany (source: http://www.esta.org.uk) FL-NET Sites http://www.mstc.or.jp/jop FLEXRAY User Group info@flexray-group.com Sites http://www.flexray-group.com Mailing list General info about the mailing list is available at http://www.flexray-group.com/mailman/listinfo/info FLUX INFORMATION PROCESSUS See FIP FMS Background Also known as: IEC 61158 Type 9. FMS (Fieldbus Messaging Specification) is not an existing fieldbus, but it is a specification for a part of a fieldbus: the application layer (OSI layer 7). FMS is modelled after MAPs MMS (Manufacturing Messaging Specification), but is much leaner and simpler; of MMSs 80+ commands only 37 were copied to FMS, but with far less capabilities. Even so, it is still a large set of commands. The first system that implemented FMS was Profibus (Profibus/FMS), but this never caught on very well because of the lack of performance, and due to the difficulties in configuring a Profibus/FMS system. To address the performance-issue, Profibus/DP was developed, which is completely different from FMS. DP caught on very well, and this made that Profibus/FMS never became a major player in the fieldbus market. Even though, the ideas expressed in FMS are not bad. Therefore, FMS has reappareared in Foundation Fieldbus. A simplified (15 commands) version is also part of Interbus, where it was originally called "PMS" (Phoenix Messaging Specification). FMS appeared in the original (January 2000) IEC 61158 standard as part of Foundation Fieldbus (Type 1), and no longer as part of Profibus (Type 3), which did not attempt to include Profibus/FMS in the standard (only DP and PA appeared). In order not to have multiple copies of the FMS specification in the IEC 61158 standard, it was decided that it would be extracted from Foundation Fieldbus, and it is now the "Type 9" in that standard. Any fieldbus system which uses FMS can now simply refer to FMS own chapter. FND See Firmenneutrales Daten Uebertragungs Protokoll FOUNDATION FIELDBUS User Group Also known as: EN 50170/A, IEC 61158 Type 1, IEC 61158 Type 5 (high-speed Ethernet version only) Fieldbus Foundation 9390 Research Blvd, Suite II-250 Austin, TX 78759-9780 (USA) Tel. +1-512-794-8890 Fax. +1-512-794-8893 Email info@fieldbus.org Fieldbus Foundation Nederland Postbus 190, 2700 AD Zoetermeer Tel. 079-3531348 Fax 079-3531365 Email ffn@fme.nl Sites http://www.fieldbus.org http://www.iceweb.com.au/Instrument/fieldbus.htm http://www.analogservices.com/papers.htm http://www.fint.no http://www.hmtutorials.com/ http://www.fieldbusinc.com/redundancyPaper.pdf http://www.ni.com (use search-engine) http://www.iceweb.com.au/ffeuca/index.htm http://www.frco.com/fr/solutions/fieldbus/techover/index.html http://www.fieldbusinc.com Literature Berge J., "Fieldbuses for Process Control: Engineering, Operation, and Maintenance". ISA Press 2002, ISBN 1-55617-760-7. Verhappen I.,"Foundation Fieldbus: A Pocket Guide". ISA Press 2002, ISBN 1-55617-775-5. Mailing List Subscribe at http://www.controleng.com/fieldbus/fieldbusfacts.asp Another mailing list (Fieldbus User Network, FUN) is maintained by the Fieldbus Foundation; send an email to fun@fieldbus.org Magazine "Catch the edge". Past issues at http://www.controleng.com/fieldbus/fieldbusfacts.htm FUNBUS Sites http://www.vdi.de/gma/fokus-1ws.htm GENIUS-BUS Sites http://www.gefanuc.com/support/plc/genius.htm http://www.gefanuc.com/infolink/manuals/90486f1.pdf HART User Group Hart Communication Foundation (HCF) 9390 Research Blvd, Suite I-350 Austin, TX 78759 (USA) Tel. +1-512-794-0369 Fax. +1-512-794-3904 Email keithk@hartcomm.org Sites http://www.hartcomm.org http://www.fieldbus.com/hart http://www.analogservices.com http://www.romilly.co.uk Magazines The "Virtual Hart Book" at www.thehartbook.com. I2C-BUS User Group Also known as: 2-Wire Bus None known. Sites http://www.ping.be/~ping0751/i2c.htm http://www.esacademy.com/faq/classes/ http://www-eu2.semiconductors.philips.com/i2c http://www.online.ro/chipdir/abc/i.htm#I2C http://www.mcc-us.com/techsrc.htm Literature Elektuur, "I2C-Bus chips en schakelingen". Uitgeverij Elektuur, ISBN 90-538-1058-7 (Dutch). Elektor, "I2C-Bus angewandt". Elektor Schaltungspraxis, 1995. (German) Paret, "The I2C Bus from theory to practice". John Wiley and Sons, 1997. ISBN 0-471-96268-6. (Apparently sold out) IBUS See European Installation Bus ICCP See Telecontrol Applications Service Element 2 IDA See Interface for Distributed Automation IDB See Intelligent Transportation Systems Data Bus IEC 870-5 See IEC 60870/5 International standard. IEC 929 See Digitally Addressable Lighting Interface International standard. IEC 9506 See Manufacturing Messaging Specification International standard. IEC 60870/5 User Group International standard. Formerly known as: IEC 870/5. None known. Sites http://www.kemaconnect.nl http://www.trianglemicroworks.com http://www.iinet.net.au/~ianw/iec870.html Mailing list http://www.trianglemicroworks.com IEC 60870/6 See Telecontrol Applications Service Element or Telecontrol Applications Service Element 2 International standard. IEC 61158 Type 1: See Foundation Fieldbus International standard. Type 2: See Controlnet Type 3: See Profibus Type 4: See P-Net Type 5: See Foundation Fieldbus Type 6: See Swiftnet Type 7: See FIP Type 8: See Interbus-S Type 9: See FMS Type 10: See ProfiNet IEC 61162/4 See Maritime Information Technology Standard International standard. IEC 61375/1 See Train Communication Network International standard. IEC 61491 See Sercos International standard. IEC 61784 See http://www.profibus.cz/archive/2000/0064.html Upcoming international standard. IEC 61850 See Utility Communications Architecture International standard. IEC 62026/2 See Actuator-Sensor Interface International standard. IEC 62026/3 See Devicenet International standard. IEC 62026/5 See Smart Distributed System International standard. IEC 62026/6 See Seriplex International standard. IEC 62136 See DMX-512 International standard. IEEE 1394 See Firewire IEEE 1451 Sites http://www.motion.aptd.nist.gov http://www.ic.ornl.gov/p1451 IEEE 1473-L See Local Operating Network Background The IEEE-1473 standard specifies "Communications Protocol Aboard Trains". It permits both TCN (see next entry) and LON as protocols. IEEE 1473-T See Train Communication Network II-O LIGHTBUS Sites http://www.trelectronic.se/light.htm I-LINK See Firewire INDUSTRIAL ETHERNET See Ethernet INSTABUS See European Installation Bus INTELLIGENT TRANSPORTATION SYSTEMS DATA BUS User Group Also known as: IDB, ITS Data Bus, J2366 IDB Forum 203 Spruce Drive, Site 200 North McMurray, PA 15317 (USA) Fax. +1-810-279-4301 Email arlan.stehney@idbforum.org Sites http://www.idbforum.org http://www.sae.org/technicalcommittees/databus.htm INTERBUS-C See Bitbus Background Interbus/C is the productname carried by Phoenix Contact for a range of remote I/O modules that could be controlled via Bitbus. These are no longer sold. INTERBUS-P See Profibus Background Interbus/P is the productname carried by Phoenix Contact for a range of remote I/O modules that could be controlled via Profibus/FMS. These are no longer sold. INTERBUS-S User Group (S=Speed, Schnell) Also known as: DIN 19-258, EN 50254/1, IEC 61158 Type 8 Interbus Club Postfach 1108 32817 Blomberg (D) Tel. +49-5235-342100 Fax. +49-5235-341234 Email info@interbusclub.com Interbus Nederland Reeuwijkse Poort 308 2810 AD Reeuwijk (NL) Tel. +31-182-391140 Fax. +31-182-391587 Email benelux@interbusclub.be Interbus België Minervastraat 12 Keiberg II 1930 Zaventem (B) Tel. +32-2-723-9848 Fax. +32-2-723-9849 Email benelux@interbusclub.be Sites http://www.phoenixcon.com http://www.ibsclub.com http://www.automation-forum.net http://www.interbusclub.com Literature Baginski, "Interbus-S: Grundlagen und Praxis, 2nd Ed.". Hüthig Verlag 1998, ISBN 3-7785-2471-2. Rose, "Prozeßautomatisierung mit Din-Meßbus und Interbus-S". Hüthig Verlag, ISBN 3-7785-2217-5. Phoenix, "Grundkurs Feldbustechnik: Interbus-Automatisierungstechnik nach IEC-61158". Vogel Verlag 2000, ISBN 3-8023-1813-7. Nickel, "Interbus-S Installation: Planung, Test, Betrieb". Pflaum Verlag, ISBN 3-7905-0701-6. Rheinisch-Westfälischer TÜV, "Bericht über die Untersuchungen am Interbus-S System". Blome, "Der Sensor/Aktorbus - Theorie und Praxis des Interbus-S". Verlag Moderne Industrie, ISBN 3-478-93090-1. Phoenix, "Interbus - Das offene und durchgängige Kommunikationssystem", ISBN 3-478-93186-X. Langmann, "Interbus: Technologie zur Automation". Hanser Verlag 1999, ISBN 3-446-19582-3. NN, "Mit Interbus in die Zukunft". Vogel Verlag 1998, ISBN 3-8259-1900-5. INTER-CONTROL CENTER COMMUNICATIONS PROTOCOL See Telecontrol Applications Service Element 2 INTERFACE FOR DISTRIBUTED AUTOMATION User Group Also known as: IDA info@ida-group.org Sites http://www.ida-group.org I/O LINK Sites http://www.gefanuc.com/infolink/manuals/gfk0823a.pdf http://www.gefanuc.com/infolink/manuals/gfk0631.pdf IP See Ethernet Industrial Protocol Not to be confused with the IP of TCP/IP. ISI-BUS Sites http://www.fint.no/fint_products_isibus.html ISO 8482 See RS-422 / 485 International standard. ISO 11519/3 See Vehicle Area Network International standard. ISO 11783 Sites International standard. http://www.agen.okstate.edu/home/mstone/ ISO 11898/1 See Controller Area Network International standard. ISO 11898/4 See Time Triggered CAN International standard. ISO 16845 See Controller Area Network International standard. ISO 17356 See OSEK/VDX International standard. ITS See Intelligent Transportation Systems Data Bus J1850 Sites http://www.motorola.com (use search-engine) http://www.intel.com/design/intarch/papers/j1850_wp.htm J1939 Sites http://www.j1939.com (limited access!) http://www.sae.org http://www.agen.okstate.edu/home/mstone/ http://www.kvaser.se/can/hlps/j1939.htm (password-protected) J2366 See Intelligent Transportation Systems Data Bus JBUS See Modbus 99% Modbus compatible. KNX See Konnex KONNEX User Group Konnex Association Twin House, Neerveldstraat 105 1200 Brussel (B) Tel. +32-2-7758590 Fax. +32-2-6755028 Sites http://www.konnex-knx.com http://www.eiba.com/konnex.html http://www.trialog.com/konnex.html KSX-6906 See Building Automation Control Network Korean standard. LANDWIRTSCHAFT- LICHES BUS SYSTEM User Group (Agricultural bus system) None known. Also known as: DIN 9-484, LBS Sites http://www.dlg-frankfurt.de/thema3/lbs/lbs.htm LBS See Landwirtschaftliches Bus System LIGHTBUS Sites http://www.beckhoff.com/english/lightbus/default.htm LIN See Local Interconnect Network LOCAL INTERCONNECT NETWORK User Group Also known as: LIN None known. Sites ftp://www.microchip.com/Download/Appnote/Category/PIC16/00729a.pdf http://www.lin-subbus.org Background European automakers Audi, BMW, DaimlerChrysler, Volvo and Volkswagen together with Motorola and Volcano Communications Technologies are the creaters of the low-cost, low-speed network bus called LIN. It is used for simple on-off devices such as car seats, door locks, sun roofs, rain sensors, HVAC flaps, cruise control, windshield wipers and mirrors, and other simple applications. LIN is much simpler than other car bus systems (such as CAN), for example one signal wire instead of two; no on-board voltage regulator, a simple electrical interfaces, and cheap microcontrollers. CAN buses are too costly for wide acceptance in noncritical applications, such as door locks and power windows. Therefore, many vehicles still use discrete point-to-point wiring to connect door locks, power windows and other simple devices to microcontrollers, costing up to hundreds of feet of wiring in thick bundles within the doors and chassis. LIN operates at 20 Kbits/s, which gives sufficient performance for the non-realtime applications where it doesnot matter if the information comes 50 milliseconds sooner or later. Each LIN bus will consist of a maximum of 16 nodes-one master and 15 slaves. Because the bus incorporates a synchronization mechanism for the slave nodes, no crystal resonator or clock source will be needed. That means that the microcontroller circuit board can be simpler and less costly. Power for the single-wire bus comes from the cars 12-volt battery. (source: EE Times) LOCAL OPERATING NETWORK User Group Also known as: ANSI 709.1, AS-5370, EIA 709.1, ENV 13154-2, IEEE 1473-L, LON, SAE AS-5370, SEMI E54.6 LONMark Interoperability Association 415 Oakmead Parkway Sunnyvale, CA 94086 (USA) Tel. +1-408-938-5266 Fax. +1-408-328-3832 Email info@lonmark.org LON Nederland p/a FME/CWM Postbus 190, 2700 AD Zoetermeer Tel. +31-79-3531349 Fax. +31-79-3531365 Email aba@fme.nl Sites http://www.echelon.com http://www.lonmark.org http://www.lno.de http://www.motorola.com (use search-engine) Literature Dietrich, "LON-Technologie: Verteilte Systeme in der Anwendung, 2nd Ed.". Hüthig Verlag 1999, ISBN 3-7785-2770-3. Harwardt, "LON - Lokal Operierende Netzwerke." Technik Verlag 1996, ISBN 3-928943-72-3. LON See Local Operating Network M3S See Multiple Master, Multiple Slave MACRO See Motion And Control Ring Optical MANUFACTURING MESSAGING SPECIFICATION User Group Also known as: IEC 9506, RS-511 None known. Sites http://www.sisconet.com/techinfo.htm ftp://www.sisconet.com/outgoing/marketin/mmsovrlg.pdf http://icawww.epfl.ch/MMS http://www.nettedautomation.com http://www.scc-online.de Literature Valenzano, "MAP and TOP Communications". Addison-Wesley, ISBN 0-201-41665-4. MARITIME INFORMATION TECHNOLOGY STANDARD User Group Also known as: IEC 61162/4, MITS MiTS Forum c/o Sintef Electronics and Cybernetics 7034 Trondheim (N) Tel. +47-7359-4351 Fax. +47-7359-4399 Email mits.forum@regtek.sintef.no Sites http://www.itk.unit.no/SINTEF/MITS/mits.html M-BUS See Meter-Bus METER-BUS User Group Also known as: M-Bus M-Bus Usergroup Fachbereich Physik, Professor Ziegler Warburger Straße 100 33098 Paderborn (D) Tel. +49-5251-602750 Fax. +47-5251-603420 Email info@m-bus.com Sites http://www.m-bus.com http://www.relay.de http://www.michaelrac.com MI-BUS See Motorola Interconnect Bus MIL-STD 1553 User Group Military standard. None known. Sites http://www.aeroflex.com/act/links03.htm> http://www.sbs-avionics.com MITS See Maritime Information Technology Standard M-LAN Sites http://www.maguire.com/software/download.htm MOBILE FIELDBUS DEVICES FOR INDUSTRY Sites European research project. Also known as: MOFDI http://www.mofdi.com Background Project MOFDI will develop and test the next generation of high speed radio connections for Fieldbuses. This significant market need is growing rapidly in importance as industrial users rely on fewer staff to cover larger areas of responsibility in their sites. Also, to save on time and access problems, Fieldbus solutions are needed to support on-line access to all field devices distributed within a plant site, including those on moving equipment and transport vehicles. The key technical feature of project MOFDI is high speed radio data communication for industrial Sensors, Actuators and Operator Interfaces. MOFDI will extend industrial Fieldbus solutions by addition of secure local connections to mobile devices which are otherwise not available for real-time data access and control. MODBUS User Group Also known as: SEMI E54.9 (Modbus/TCP only) None known. Sites http://www.modbus.org http://www.modicon.com/techpubs/toc6.html http://www.modicon.com/techpubs/toc7.html http://www.modicon.com/openmbus/ http://jmodbus.sourceforge.net (Free Java-implementation) http://www.tracker2.narod.ru (Open-source COM/DCOM Modbus server, with doc in Russian) http://www.robustdc.com/mbus_tcp.htm http://www.lancontrols.com http://members.tripod.com/~mbserver Mailing list See http://www.modbus.org/discforum_frm.htm MOFDI See Mobile Fieldbus Devices For Industry MOTION AND CONTROL RING OPTICAL User Group Also known as: MACRO None known. Sites http://www.macro.org MOTOROLA INTERCONNECT BUS User Group Also known as: MI-Bus None known. Sites http://www.mot-sps.com/lit/html/an475.html MPI See Multi-Point Interface MULTI-POINT INTERFACE User Group Also known as: MPI None known. Sites http://www.runmode.com MULTIPLE MASTER, MULTIPLE SLAVE User Group Also known as: M3S M3S Dissemination Office p/a TNO Institute of Applied Physics POBox 155, 2600 AD Delft (NL) Tel. +31-15-2692004 Fax. +31-15-2692111 Email m3s@tpd.tno.nl Sites http://www.tno.nl/m3s/ MULTIPURPOSE VEHICLE BUS See Train Communication Network MVB See Multipurpose Vehicle Bus NATIONAL TRANSPORTATION COMMUNICATION ITS PROTOCOL User Group Also known as: NTC/IP None known. Sites http://www.ite.org/standards http://www.ntcip.org NETWORK ORIENTED APPLICATION HARMONISATION Sites Research project. Also known as: NOAH http://noah.loria.fr http://www.fzi.de/mrt/projects/noah.html NFC 46620 See Batiment Intelligent Bus French standard. NOAH See Network Oriented Application Harmonisation NIOBRARA R&D TCP Sites http://www.niobrara.com/nrdtcp.html NTC/IP See National Transportation Communication ITS Protocol OLCHFA See Open Low-cost Time-critical Wireless Fieldbus Architecture OPEN LOW-COST TIME-CRITICAL WIRELESS FIELDBUS ARCHITECTURE Sites Research project. Also known as: OLCHFA http://www.faps.uni-erlangen.de/persons/stoeckel/olchfa/olchfa.html http://cabernet.esprit.ec.org/esp-syn/text/7210.html OPEN THERM User Group Open Therm Club Holland p/a FME/CWM Postbus 190, 2700 AD Zoetermeer Tel. +31-79-3531359 Fax. +31-79-3531365 Email cdr@fme.nl Sites None known. Background This protocol was originally developed by Honeywell for use in building heating installations and the associated thermostats. Later, the protocol was handed over to the Open Therm vendor association. OPTOMUX Sites http://www.opto22.com (use search-engine) OSEK/VDX User Group Also known as: ISO 17356 None known. Sites http://www.osek-vdx.org http://www.kvaser.se/can/hlps/osek.htm http://www-iiit.etec.uni-karlsruhe.de/~osek PACTWARE User Group None known. Sites http://www.pactware.com Background PACTWare is not a fieldbus, but a consortium of (German) companies headed by Pepperl & Fuchs. Its goal is to develop a (Windows-based) software-tool using the FDT (Field Device Tool) and the associated DTMs (Device Type Managers), for those systems where a DCS is not used. Basically it is an application framework, in which individual DTMs can be connected and executed, as if it were a single software application. This allows a clear distinction between network device functions, service functions, and asset management functions (trend curve, value monitoring, etc.) via yet other plug-in software modules. It allows device manufacturers to encapsulate and control their devices via a DTM, without having to reveal their device-secrets to other companies, while still allowing their device to be used by system vendors. The PACTWare software was developed by Pepperl & Fuchs, and can be downloaded from the website after signing the P&F Open Source License. PARALLEL BUSSES This list only keeps URL"s of serial networks. More information about parallel systems can be found at: http://www.techfest.com/hardware/bus.htm P-NET User Group Also known as: DSF 21906, EN 50170/, IEC 61158 Type 4 International P-NET Users Organisation ApS (IPUO) POBox 192 8600 Silkeborg (DK) Tel. +45-87-200-396 Fax. +45-87-200-397 Email p-net@post4.tele.dk Sites http://www.ict.tuwien.ac.at/komzent/p-net/index.html http://www.proces-data.dk/ http://www.p-net.dk/ PRENORMATIVE REQUIREMENTS FOR INTELLIGENT ACTUATION AND MEASUREMENT Sites Research project. Also known as: PRIAM http://cabernet.esprit.ec.org/esp-syn/text/6188.html PRIAM See Prenormative Requirements For Intelligent Actuation And Measurement PROCESS FIELDBUS See Profibus PROFIBUS User Group Also known as: DIN 19-245, EN 13321-1 (Profibus/FMS only), EN 50170/2, EN 50254/2, IEC 61158 Type 3, Process Fieldbus, SEMI E54.8 (Profibus/DP only), JB/T10308.3-2001 Profibus User Group e.V. (PNO) Haid-und-Neu Straße 7 76131 Karlsruhe (D) Tel. +49-721-9658-590 Fax. +49-721-9658-589 Email profibus_international@compuserve.com Profibus Nederland p/a FME/CWM Postbus 190, 2700 AD Zoetermeer (NL) Tel. +31-79-3531353 Fax. +31-79-3531365 Email profibus@fme.nl Profibus Belgium August Reyerslaan 80 1030 Brussel (B) Tel. +32-2-707-8000 Fax. +32-2-706-8009 Email herman.looghe@fabrimetal.de Sites http://www.profibus.com http://www.profibus.ch Very informative! http://www.ifak.fhg.de/kommunik/deutsch/PbHome.htm http://www.aut.sea.siemens.com/pic http://www.profichip.com Literature Bender, "Profibus: Der Feldbus für die Automation". Hanser Verlag 1990, ISBN 3-446-17283-1 (apparently sold out). Bender, "Profibus: The fieldbus for industrial applications". ISBN 1-3-012691-8 (apparently sold out). VDI Berichte 728, "Offene Kommunikation im Feldbereich mit Profibus". VDI Verlag, ISBN 3-18-090728-2. VDI Berichte 844, "Standardisierter Feldbus für die elektrische Antriebstechnik". VDI Verlag, ISBN 3-18-090844-0. VDI Berichte 962, "Profibus Profil Drehzahlveränderbare Antriebe". VDI Verlag 1992, ISBN 3-18-090962-5. Kester, "An intelligent weight controller using Profibus". TU Eindhoven 1997. Rindle, "Der Profibus". Vogel Verlag 1995, ISBN 3-929802-43-0. Brunner, "Profibus mit PC-UESR". Vogel Verlag 1995, ISBN 3-929802-51-1. Profibus Nutzer Organization, "Profibus/DP - Schnelleinstieg". Best. Nr. 4.071 Popp, "Profibus-DP/DPV1: Grundlagen, Tips und Tricks für Anwender, 2nd Ed.". Hüthig Verlag 2000, ISBN 3-7785-2781-9. Weigmann, "Decentralization with Profibus/DP (2nd ed.)". Siemens 2000, ISBN 3-89578-144-4. Weigmann, "Dezentralisieren mit Profibus/DP (2nd ed.)". Siemens 2000, ISBN 3-89578-123-1. Mailing list The archive and further instructions can be found at www.profibus.cz/archive Courses by the author In cooperation with the Mikrocentrum in Eindhoven we host a course on Profibus, starting in April. Duration is 3 weeks, one evening per week. Locations are Eindhoven and Utrecht. Language Dutch. The course can also be given in-company; contact R.Bus@mikrocentrum.nl for more information. Documentation by the author The proficonf.pdf document (Dutch) describes a step-by-step plan to configure a Profibus/FMS network. I learned it the hard way! PROFICELL See Programmable Fieldbus Cell PROFINET See Profibus Also known as: IEC 61158 Type 10. Background ProfiNet is the next member of the Profibus-family of protocols. It is an industrial Ethernet based system, to which a "proxy" module must be connected which in turn communicates with a Profibus/DP or /PA system. As of 12/2001, the Profinet is still in development, with the current Ethernet-part useable for management, configuration and diagnostics of the underlying (via the proxy) Profibus-networks, where the real work is done. The ProfiNet specification is given in Type 10 of the IEC 61158 standard. The specification heavily relies on Microsoft COM/DCOM technology. In contract to a statement made during a press conference at the end of 2000, where it was said that ProfiNet will be "open source", the source code is actually only available for members of the Profibus User"s Group. As of this moment, ProfiNet equipment is available from a few suppliers (such as Siemens). PROGRAMMABLE FIELDBUS CELL Sites Research project. Also known as: Proficell http://cabernet.esprit.ec.org/esp-syn/text/8601.html RADIO FIELDBUS Sites http://www.rfieldbus.de RAILWAY OPEN SYSTEM INTERCONNECTION NETWORK User Group Also known as: ROSIN None known. Sites http://www.labs.it/rosin ROSIN See Railway Open System Interconnection Network RS-232 Sites Recommended standard. Also known as: EIA/TIA-232 http://www.linuxdoc.org/HOWTO/Serial-HOWTO.html http://www.lvr.com/serport.htm http://ourworld.compuserve.com/homepages/richard_grier (VB serial programming) http://www.vhmiautomation.com (PLC Communication in ActiveX) RS-422 / 485 Sites Recommended standard. Also known as: EIA/TIA-422/485, ISO 8482 http://www.bb-elec.com/technical_library.asp http://www.arcelect.com/485info.htm http://www.national.com/catalog/AnalogInterface_DataTransmissionCircuits_RS485.html http://www.kksystems.com/serdesc1.html http://www.edtn.com/embapps/emba062.htm http://www.rs485.com http://www.robustdc.com RS-511 See Manufacturing Messaging Specification Recommended standard. SAE AS-5370 See AS-5370 SAFETYBUS User Group SafetyBus p Club International e.V. Felix Wankel Straße 2 73760 Ostfildern (D) Tel. +49-711-3409-118 Fax. +49-711-3409-134 Email info@safetybus.com Sites http://www.safetybus.com SAN See Sensor-Actuator Network SBS See Smart Battery Bus SCALEABLE NODE ADDRESS PROTOCOL User Group Also known as: SNAP None known. Sites http://www.hth.com/snap SCRAMNET Sites http://www.systran.com SDI See Serial Data Interface SDS See Smart Distributed System SECS-I, -II See Semiconductor Equipment Communication Standard SEMICONDUCTOR EQUIPMENT COMMUNICATION STANDARD User Group Also known as: SECS-I, SECS-II None known. Sites http://www.semi.org http://www.gwainc.com SEMI E54.1 Sites Also known as: SAN, Sensor-Actuator Network http://www.semi.org Background This specification provides the structure of SEMI"s Sensor/Actuator Network (SAN) standard. It provides the definition for interoperability with respect to SEMI SAN standard-compliant Sensor/Actuator devices. This standard specifies how devices interoperate on a network as part of the control system for equipment. This specification, which is the root of the SAN standard, defines the relationships of each of the other specifications which are components of the SEMI SAN standard. This standard defines a model comprised of device objects which are common to all devices on a semiconductor equipment sensor/actuator communications network. This document describes common device structure and behavior (i.e., the minimum data structure and behavior all devices must support to operate on the network). These devices may range from simple sensors and actuators through hosts, masters, or controllers. The model specified in this document is used in conjunction with a sensor/actuator network specific device model which describes the data structure and behavior characteristic of the specific device. Together, these two models are sufficient to completely describe a device as it appears from the network interface. This standard, together with a sensor/actuator network interoperability guideline, a sensor/actuator network communication specification (see below: E54-4 and further), and one or more specific device model specifications, form a complete interoperability specification. To comply with this standard, a device must implement and support instances of the objects, object attributes, object services, and object behaviors identified in this document, unless explicitly stated otherwise (source: SEMI website). SEMI E54.4 See Devicenet Formerly known as E59. Background This standard defines a communication specification based on the DeviceNet protocol to enable communications between intelligent devices on a sensor/actuator network (SAN) that operate according to SEMI specified device models (common and device specific) in a semiconductor manufacturing tool. DeviceNet provides for networking between simple industrial devices (e.g., sensors and actuators) and higher level devices such as controllers. This document enables communications between intelligent devices on a SEMI compliant SAN by providing a presentation mapping of common and specific device network visible structure and behavior to a DeviceNet network. This document specifies the protocol and services that compliant intelligent devices must support to interchange information over this semiconductor equipment sensor/actuator network. This document specifies the utilization of the DeviceNet protocol to present externally visible device structure and behavior, specified in the Common Device Model (CDM) and appropriate Specific Device Models (SDM"s), on a DeviceNet network. (source: SEMI website) SEMI E54.5 See Smart Distributed System Formerly known as E60. Background This standard defines a communication protocol based on the Smart Distributed System (SDS) to enable communications between intelligent devices on a sensor/actuator network (SAN) to be used in semiconductor manufacturing equipment. This document specifies a SAN communications standard based on the Smart Distributed System (SDS) specification that is in compliance with the SEMI SAN Common Device Model specification. This document specifies the protocol and services that compliant intelligent devices must support to interchange information over this semiconductor equipment sensor/actuator network. (source: SEMI website) SEMI E54.6 See Local Operating Network Formerly known as E61. Background This standard defines a communication specification based on the LonWorks technology specification to enable communications between intelligent devices on a sensor/actuator network (SAN) that operate according to SEMI specified device models (common and device specific) in a semiconductor manufacturing tool. This document specifies a mapping of the SEMI common device model (CDM) onto LonWorks technology using the LonMark Interoperability Guidelines established for LonWorks devices. The LonMark Interoperability Association may incorporate into the Interoperability Guidelines any enhancements presented in this document. The SEMI standard for LonWorks is based on the LonMark interoperability guidelines, which provide a framework for interoperable use of the LonTalk Protocol at layers 1-6, as well as at the application layer. Where the LonMark interoperability guidelines do not provide the functionality required by the SEMI CDM, the guidelines are extended with SEMI-specific requirements. This document specifies a SAN communications standard based on the LonWorks specification, that enables communication with SAN devices configured according to the SEMI SAN Common Device Model and appropriate Specific Device Model (SDM) specifications. This document specifies the use of LonWorks technology for services that compliant intelligent devices must support in order to exchange information over this semiconductor equipment sensor/actuator network. (source: SEMI website) SEMI E54.7 See Seriplex Background This standard defines a communication specification based on the Seriplex protocol to enable communications between intelligent devices on a sensor/actuator network (SAN) that operate according to SEMI specified device models (common and device specific) in a semiconductor manufacturing tool. This document enables communications between intelligent devices on a SEMI compliant SAN by providing a presentation mapping of common and specific device network visible structure and behavior to a Seriplex network. This document specifies the protocol and services that compliant intelligent devices must support to exchange information over this semiconductor equipment sensor/actuator network. This document specifies the utilization of the Seriplex protocol to present externally visible device structure and behavior, specified in the Common Device Model (CDM) and appropriate Specific Device Models (SDMs), on a Seriplex network. This document is used in conjunction with a SEMI standard SAN Common Device Model specification, one or more SEMI standard Specific Device Model (SDM) specifications (e.g. for a mass flow controller) and the Seriplex Standard Specification. Together, they describe the Seriplex protocol, the externally visible data structures and behaviors of devices utilizing the Seriplex networking capability in a SEMI compliant SAN system. (source: SEMI website) SEMI E54.8 See Profibus/DP Background This specification is part of the SEMI Sensor/Actuator Network (SAN) suite of standards and defines a specific communications protocol based on the PROFIBUS-DP standard. This standard, taken together with the SEMI Sensor/Actuator Network standard suite and the PROFIBUS standard completely and unambiguously defines an open standard providing an industry specific solution to off-the-shelf interoperability of networked devices in semiconductor manufacturing equipment. This document specifies a SAN communications standard based on the PROFIBUS-DP specification that is in compliance with SEMI E54.1. As such, it specifies the protocol, services, and behavior that compliant intelligent devices must support in order to interchange information over this SAN in a method compatible with SEMI E39. In conjunction with a SEMI standard SAN Common Device Model (CDM) specification and one or more SEMI standard Specific Device Model (SDM) specifications (e.g., for a mass flow controller), this standard with the related PROFIBUS-DP standard describe the data structures, interactions, and behavior that are characteristic of the various devices on the network. This composite model forms a complete interoperability standard for communications among intelligent sensors, actuators, and controllers in semiconductor manufacturing equipment. (source: SEMI website) SEMI E54.9 See Modbus/TCP Background This standard defines a communication specification based on the Modbus/TCP protocol over a TCP/IP network to enable communications between intelligent devices on a sensor/actuator network (SAN) that operate according to SEMI specified device models (common and device specific) in a semiconductor manufacturing tool. This document enables communications between intelligent devices on a SEMI compliant SAN by providing a presentation mapping of common and specific device network visible structure and behavior to Modbus/TCP over a TCP/IP network. This document specifies the protocol and services that compliant intelligent devices must support to exchange information over this semiconductor equipment sensor/actuator network. This document specifies the utilization of the Modbus/TCP protocol to present externally visible device structure and behavior, specified in the Common Device Model (CDM) and appropriate Specific Device Models (SDMs), for the Modbus/TCP protocol over a TCP/IP network. This document is used in conjunction with a SEMI standard SAN Common Device Model specification, one or more SEMI standard Specific Device Model (SDM) specifications (e.g., for a mass flow device), the Modicon Modbus Protocol Reference Guide and the Open Modbus/TCP Specification. Together, they describe the Modbus/TCP protocol, the externally visible data structures and behaviors of devices utilizing the Modbus/TCP networking capability in a SEMI compliant SAN system. (source: SEMI website) SEMI E54.12 See CC-Link Background This specification is part of the SEMI Sensor/Actuator Network (SAN) suite of standards and defines a specific communications protocol based on the CC-Link standard. This standard, taken together with SEMI E54.1 and the CC-Link standard completely and unambiguously defines an open standard providing an industry specific solution to off-the-shelf interoperability of networked devices in semiconductor manufacturing equipment. This document specifies a SAN communications standard based on the CC-Link specification that is in compliance with SEMI E54.1. As such, it specifies the protocol, services and behavior that compliant intelligent devices must support in order to interchange information over this SAN in a method compatible with SEMI E39. In conjunction with a SEMI standard SAN Common Device Model (CDM) specification and one or more SEMI standard Specific Device Model (SDM) specifications (e.g., for a mass flow controller), this standard with the related CC-Link standard describe the data structures, interactions and behavior that are characteristic of the various devices on the network. This composite model forms a complete interoperability standard for communications among intelligent sensors, actuators and controllers in semiconductor manufacturing equipment.This standard does not purport to address safety issues, if any, associated with its use. It is the responsibility of the users of this standard to establish appropriate safety health practices and determine the applicability or regulatory limitations prior to use. (source: SEMI website) SENSOR/ACTUATOR NETWORK See SEMI E54.1 SENSOPLEX Sites http://www.turck.com/2plex2.htm SERCOM Sites http://www.k-team.com/software/sercom.html SERCOS See Serial Real-time Communications System SERIAL DATA INTERFACE User Group Also known as: SDI-12 SDI-12 Support Group 135 East Center Logan, UT 84321 (USA) Tel. +1-801-752-4200 Email infoman@sdi-12.org Sites http://www.sdi-12.org SERIAL REAL-TIME COMMUNICATION SYSTEM User Group Also known as: DIN 61-49, IEC 61491, SERCOS Interest group SERCOS Interface e.V. (IGS) Landhausstrasse 20 70190 Stuttgart (D) Tel. +49-711-28457-50 Fax. +49-711-28457-55 Email info@sercos.de Sites http://www.sercos.com http://www.sercos.org SERIES NINETY PROTOCOL User Group Also known as: SNP None known. Sites http://www.gefanuc.com/infolink/manuals/gfk0585a.pdf SERIPLEX User Group Also known as: IEC 62026/6, SEMI E54.7 Seriplex Technology Organization (STO) POBox 27446 Raleigh, NC 27611 (USA) Tel. +1-919-217-6503 Fax. +1-919-217-6625 Sites http://www.seriplex.org SI-BUS See Byteflight SIRIUSNET See Actuator/Sensor-Interface Productname of Siemens. S-LINK Sites http://www.sunx.co.jp/english/syouhin/slink/kk_index.html SMART BATTERY BUS User Group Also known as: SBS SBS Implementers Forum c/o Intel Corporation 2200 Mission College Boulevard RN6-44 Santa Clara, CA 95052 (USA) Email webmaster@sbs-forum.org Sites http://www.sbs-forum.org SMART DISTRIBUTED SYSTEM User Group Also known as: EN 50325/3, IEC 62026/5, SDS, SEMI E54.5 None known. Sites http://www.honeywell.com/sensing/prodinfo/sds/ SMARTHOUSE User Group Smart House, Inc. Corporate office 4630 Paragon Park Road Raleigh, NC 27616 (USA) Tel. +1-919-872-8553 Fax. +1-919-790-9670 Sites http://www.smart-house.com/ SMBUS See System Management Bus SNAP See Scaleable Node Address Protocol SNP See Series Ninety Protocol SP50 User Group Standardisation committee. None known. Sites http://www.isa.org/sc/committee/1,1293,66,00.html SWIFTNET User Group Also known as: IEC 61158 Type 6 None known. Sites http://www.shipstar.com/swiftnet.htm SYSTEM MANAGEMENT BUS User Group Also known as: SMBus None known. Sites http://www.smbus.org TASE.1 See Telecontrol Applications Service Element 1 TASE.2 See Telecontrol Applications Service Element 2 TCN See Train Communications Network TELECONTROL APPLICATIONS SERVICE ELEMENT 1 User Group Also known as: Elcom, IEC 60870/6, TASE.1 None known. Sites http://www.kemaconnect.nl TELECONTROL APPLICATIONS SERVICE ELEMENT 2 User Group Also known as: ICCP, IEC 60870/6, Inter-control Center Communications Protocol, TASE.2 None known. Sites http://www.epri.com http://www.sisconet.com/techinfo.htm ftp://www.sisconet.com/epri http://www.nettedautomation.com/links TIME TRIGGERED CAN See Controller Area Network Also known as: IEC 11898/4, TTC, TTCAN TIME TRIGGERED PROTOCOL User Group Also known as: TTP. Variations are known as TTP/A, TTP/C and Time Triggered Sensor Bus. TTP FORUM c/o TTTech Computertechnik AG Schönbrunner Strasse 7 1040 Wien (A) Tel. +43-1-585-343416 Fax. +43-1-585-343490 Email office@ttpforum.org Sites http://www.ttpforum.org http://www.tttech.com http://www.sp.se/pne/software&safety/palbus/eng/report.htm http://www.amsint.com/automotive http://www.mot-sps.com/automotive/ttpc.html http://www.vmars.tuwien.ac.at http://www.setta.org TIME TRIGGERED SENSOR BUS User Group Also known as: TTSB, TTP/A None known. Sites http://www.lpr.e-technik.tu-muenchen.de/~rhuber/forschung/forschung.htm TRAIN COMMUNICATION NETWORK User Group Also known as: IEC 61375/1, IEEE 1473-T, Multipurpose Vehicle Bus, MVB, TCN, Wire Train Bus, WTB None known. Sites http://www.labs.it/rosin/gistanda.htm TTC See Time Triggered CAN TTP See Time Triggered Protocol TTSB See Time Triggered Sensor Bus UCA See Utility Communications Architecture UNIVERSAL SERIAL BUS User Group Also known as: USB USB Implementers Forum (USB-IF) 5440 SW Westgate Dr. Suite 217 Portland, OR 97221 (USA) Tel. +1-503-296-9892 Fax. +1-503-297-1090 Email admin@usb.org Sites http://www.usb.org http://www.flexiusb.com http://www.catc.com http://developer.intel.com/technology/usb http://www.semtech.com/developer/index.html Literature Anderson, "Universal Serial Bus Architecture". Addison Wesley 1997, ISBN 0-201-46137-4. Kelm, "USB - Universal Serial Bus". Franzis Verlag 1999, ISBN 3-7723-7962-1. USB See Universal Serial Bus UTILITY COMMUNICATIONS ARCHITECTURE User Group Also known as: IEC 61850, UCA None known. Sites http://www.epri.com http://www.sisconet.com/techinfo.htm ftp://www.sisconet.com/epri/uca2.0 http://www.kemaconnect.nl http://www.nettedautomation.com http://www.scc-online.de Background World-wide, electric utility deregulation is expanding. It creates demands to integrate, consolidate and dissiminate real-time information quickly and accurately within and with power generating systems and substations. The objective of UCA is to dramatically improve device data integration, reducing the costs for engineering, commissioning, operation, monitoring, diagnostics, asset management, and maintenance during the whole life cycle of a substation. UCA differs from most other utility protocols in its use of object models of device functions and device components. These models define common data formats, identifiers, and controls for substations and feeder devices such as measurement units, switches, voltage regulators, and protection relays. The reduced bandwith costs and increased processing capabilities in the end devices allow them to carry metadata: 2000+ standardized classes with their names and types are specified for the most common devices. They can be used by applications for online verification of the integration, and configuration of databases. This self-description of data is stored in the devices themselves, which reduces the cost of data management (configuration) and reduces down time due to configuration errors. (source: www.nettedautomation.com). VAN See Vehicle Area Network VEHICLE AREA NETWORK User Group Also known as: ISO 11519/3, VAN None known. Sites http://www.van-mux.org http://www.van-bus.org (Since a few months password-protected) Literature Abou, "Le bus VAN: Fondements du protocole". Dunod 1997. V-NET Sites http://www.yokogawa.co.jp/Information/Report/pdf/English/No23/23_06.pdf VOLCANO Sites http://www.vct.se http://www.tech.volvo.se/rt/trmag WIRE TRAIN BUS See Train Communication Network WORLDFIP See Factory Instrumentation Protocol WTB See Wire Train Bus X10 User Group X10 Technology and Resource Forum (X10.ORG) Email info@x10.org Sites http://www.x10.org http://www.x10.com http://web.cs.ualberta.ca/~wade/HyperHome http://www.smarthome.com/smarthome/index.html ftp://oak.oakland.edu/pub/simtelnet/msdos/x_10
工控三段
  • 帖子:18帖 | 184回
  • 年度积分:725
  • 历史总积分:6114
  • 注册:2003年1月08日
发表于:2005-06-01 17:21:00
o
岁月似梦
  • 帖子:4帖 | 204回
  • 历史总积分:259
  • 注册:2005年10月26日
发表于:2005-11-28 15:58:00
看不懂啊
梦落花时
  • 求助:1帖
  • 帖子:1帖 | 76回
  • 历史总积分:479
  • 注册:2020年4月18日
发表于:2020-04-28 10:02:44
4楼
waht are you talk about ? i could not understand what do you say
